5.2L 318 Electrical Plug ID - JeepForum.com
post #1 of 13 Old 06-18-2017, 02:41 PM Thread Starter
GSXRSTORM
1994 ZJ
I did an engine swap from a 95 5.2L 318 to a 94 5.2L 318 with my mechanic friend, we got most of the way done and it's running and drivable (yes it's throwing off a check engine light) and then he got deployed for the next 8 months. So while he is gone I've been working on the interior however this one Plug keeps bugging me and I am trying to find where it goes...any help or suggestions would be greatly appreciated.
GSXRSTORM is offline
post #2 of 13 Old 06-18-2017, 05:21 PM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
It looks like the EGR valve connector plug.
wingless is offline
post #3 of 13 Old 06-19-2017, 11:42 AM Thread Starter
GSXRSTORM
1994 ZJ
It looks exactly like the EGR sensor plug on the other side and is what I initially thought as well. I thought maybe I got it on the wrong side but if I switch the sensor to this side I run into the same problem on the other side.
post #4 of 13 Old 06-19-2017, 01:09 PM
wingless
wingless's Avatar
1994 ZJ
What does "the other side" mean?
There is only one EGR valve and only one EGR connector.
It is on the passenger side.
wingless is offline
post #5 of 13 Old 06-19-2017, 06:31 PM Thread Starter
GSXRSTORM
1994 ZJ
Ah, I have the EGR valve connector plug on the driver side of the engine. So I will put it over to the passenger side and trace back the plug on the driver side and find out where it goes.
post #6 of 13 Old 06-19-2017, 07:46 PM
wingless
wingless's Avatar
1994 ZJ
This shows the rear engine connectors.
There is the EGR connector on the passenger side, the evaporator purge solenoid vacuum port connector on the driver's side, the idle air control throttle body connector in the middle and the distributor camshaft position sensor in the middle.
wingless is offline
post #7 of 13 Old 06-19-2017, 08:46 PM Thread Starter
GSXRSTORM
1994 ZJ
Wingless, thank you so much that completely clears up so much...Will have to get home and check a few things now and fix them tomorrow.
post #8 of 13 Old 06-20-2017, 07:18 AM
wingless
wingless's Avatar
1994 ZJ
Glad to help.
The image shows the TSB 18-48-98 for the spark plug wire routing.
wingless is offline
post #9 of 13 Old 06-20-2017, 08:52 AM Thread Starter
GSXRSTORM
1994 ZJ
Now that I am reading this I am glad that I kept everything from the old build because now I am finding all these parts and now it's just a matter of fixing these small issues.
post #10 of 13 Old 06-20-2017, 10:30 AM Thread Starter
GSXRSTORM
1994 ZJ
Hey Wingless, by chance do you have a picture of the front of the engine...at this point I'm wanting to make sure I have everything set up correctly?
post #11 of 13 Old 06-20-2017, 11:26 AM
wingless
wingless's Avatar
1994 ZJ
Here are more images.
Good luck.
wingless is offline
post #12 of 13 Old 06-23-2017, 12:16 PM Thread Starter
GSXRSTORM
1994 ZJ
thank you
Wingless thank you again so much, your pictures helped out and I was able to get everything fixed up and now no more engine light...for now.
Again thank you.
post #13 of 13 Old 06-23-2017, 12:39 PM
wingless
wingless's Avatar
1994 ZJ
You are welcome.
Glad to help.
wingless is offline
