5.2 ZJ got too hot, what to expect? - JeepForum.com
post #1 of 6 Old 06-19-2017, 12:19 PM Thread Starter
Kade97
I just tried to post a better explanation of the issue, but since I have to type this again I will make it short and sweet.
power steering pulley came off along with the belt which caused the temp gauge to get to half way between 210 and RED/HOT before I could park it. The mirrors randomly reset before I could get the car turned off.
After getting a pump, pulley, and hose installed, are there any issues I should be aware of due to possible overheat?
I probably wont have it back on the road till Wednesday but I want to know if there are any possible problems I should expect.
Kade97 is offline
post #2 of 6 Old 06-19-2017, 12:38 PM
kg6mov
Hears the voices
kg6mov's Avatar
IMO, halfway isn't overheating. I've taken my engine up to the 260 mark a few times when I forgot to plug the efan back in, no real issues once it was cooled down.
As long as you didn't do something silly like immediately throw cold coolant in it you should be fine.
kg6mov is offline
post #3 of 6 Old 06-19-2017, 01:26 PM Thread Starter
Kade97
Good to know, Thanks man
Kade97 is offline
post #4 of 6 Old 06-20-2017, 03:44 AM
dflewelling
You'll be fine. These magnum motors are tough as nails. I once had one go red on me, no I'll effect after the root cause was fixed. I wouldn't lose sleep over it.
Sent from my SM-G935V using Tapatalk
dflewelling is offline
post #5 of 6 Old 06-20-2017, 04:24 PM
Luke4010
I blew my radiator out about a year ago and limped the jeep home. I would wait till it got to the 3/4 mark on the gauge and shut it off and let it cool down. Did that about 4 times before I got home and she's still running strong today. You shouldn't have anything to worry about.
Luke4010 is offline
post #6 of 6 Old 06-20-2017, 10:13 PM
StPaul59
I've had the plastic tank style radiator leak shortly after running hot. And a heater core leak after running hot as well.
StPaul59 is offline
