5.2 will crank but wont turn over - JeepForum.com
post #1 of 2 Old 07-30-2009, 01:52 PM Thread Starter
95ZJL
95ZJL's Avatar
plain and simple, i went through about a foot of water at a local offroad area. i have 2 inch spacers and 31's so it was not a problem, however though, as i came to the end of the trail, i turned right and then my jeep died. i thought it was hydrolocked, so i removed all plugs and got some moisture out of the cylinders, then i recharged the battery and checked the air filter and fuel pressure, and still no start. someone help!! also! im not sure if its necessary but i dont think my cap and rotor could have possibly gotten wet.
The line isn't about the motive, it's merely the result.
1995 ZJ Limited Black/Gold
5.2 V8 NEW 249
2" Doestch 3000 Shocks
31x10.5 BFG All-Terrain's
KOR Radiator Support
95ZJL is offline
post #2 of 2 Old 07-30-2009, 03:28 PM
newfieZJ
check your fuses and relays , check the spark , the coil and then your CPS .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
4.0 Will crank but won't turn 96ZjBurner ZJ Grand Cherokee Forum 24 11-04-2009 07:50 PM
4.0 Wont Crank spannerman ZJ Grand Cherokee Forum 0 09-19-2009 07:48 AM
02 Wj Bizarre turn signal wont turn off mountcharles ZJ Grand Cherokee Forum 0 05-05-2009 02:51 PM
4.0 will crank but won't turn ben_wagner ZJ Grand Cherokee Forum 7 02-04-2009 06:04 PM
4.0L will crank but won't turn over, need help!!!!!! jeepdude85 ZJ Grand Cherokee Forum 4 09-02-2008 08:10 PM
