5.2 serpentine belt with A/C bypass length - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.2 serpentine belt with A/C bypass length
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 02-14-2015, 02:50 PM   #1
FredDemara
I have a 94 5.2 4wd. The air no longer works, and today I figured it would be a good day to remove the compressor and shorten the belt.
After several calls to jeep dealership and several automotive shops, Napa told me to get as close a measurement as I could, and bring the old belt in.
The belt they gave me part number 25/070834. This is a Napa belt, the micro-v AT series. The belt fit perfectly (84 inches long) and the jeep is having no issues, and running 100% with the shorter belt on. Belt cost about 40 bucks.
Seen the question asked about the shorter belt in a few places, couldn't find an answer. Hope this helps someone else.
1994 Grand Cherokee
FredDemara is offline   Reply With Quote Quick reply to this message
Unread 02-14-2015, 05:44 PM   #2
fishermandave95
82 1/2in I got a dayco #5060825 it buy passes the a/c
fishermandave95 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2015, 06:16 PM   #3
jeeepguy
Wow, deep south and no A/C. Why not just fix it?
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote Quick reply to this message
Unread 02-14-2015, 06:18 PM   #4
fishermandave95
Redneck a/c 55mph and the windows down
Unread 02-14-2015, 07:14 PM   #5
Cbob4
We call that 270 air. Want it cooler? 470...
Cbob4 is online now   Reply With Quote Quick reply to this message
Unread 02-14-2015, 07:18 PM   #6
FredDemara
well, I only paid 900 bucks for it...and I use it for my dogs...that usually have their heads sticking out...and it doesn't have a roof.
http://www.youtube.com/watch?v=JiJuHZLijY4
1994 Grand Cherokee
Unread 02-14-2015, 07:21 PM   #7
FredDemara
saw that...at 82.5, I had to push the tensinor hard, hard to the right. Was very worried about damaging the bearings in the power steering pump.
1994 Grand Cherokee
Unread 02-14-2015, 07:52 PM   #8
fishermandave95
Dint seam to hard on mine when I did It and is how I will be running it when I get back on the road . Ran it under the a/c pully and it all slipped right on
Unread 02-14-2015, 08:23 PM   #9
FredDemara
There was a diagram on the radiator support showing the correct routing on mine - was very grateful it lasted 20 years! The 84 inch gave the tensinor about 3/4 inch of room to move back to the rear...so it was under tension. I would say it had about a range of 3 inches from full tension to none, at least that's what I had measured on the old belt I used for reference.
The deflection on the belt at it's longest point (top of alt to crank balancer?) was within spec. If it squeals at all, I'll go shorter.
1994 Grand Cherokee
