5.2 replacing head, any cheap mods? - JeepForum.com
post #1 of 9 Old 12-18-2013, 07:54 PM Thread Starter
41jeep41
2010 JK Wrangler
This is my first post on the ZJ forum, I am a JK owner but wanted something to keep miles and the winter salt off of the JK. I have fallen in love with my 98 5.2 and enjoy the V8 ( ) much more than the puny V6 in the JK.
With that said LONG story short I have to replace the head on the motor, I was wondering if there were any cheap mods I could do to the motor/head since I have the head off of the engine to help increase power at all. If there are any write ups I would greatly appreciate links.
Thank you!
A first time ZJ owner
41jeep41 is offline
post #2 of 9 Old 12-18-2013, 08:11 PM
OverlandZJ
Get ready for the "Just drop in a 5.9" crowd...
You'll also hear to use the Hughes plenum gasket when you put it back together. They have a pretty good site.. might wanna look it over.
http://www.hughesengines.com/Index/index.php
OverlandZJ is offline
post #3 of 9 Old 12-19-2013, 09:34 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
you mean heads, not head right?
Use thinner head gaskets, as that will increase the compression ratio a little. Gasket match all the ports with a Dremel.
Get aluminum heads, that makes a big difference. They are lighter and you can go 10:1 or more on the compression ratio because they run cooler.
HighLonesome is offline
post #4 of 9 Old 12-19-2013, 05:31 PM Thread Starter
41jeep41
2010 JK Wrangler
Thanks for the information, I am going to be ordering the other parts I need and putting it all back together later this week.
41jeep41 is offline
post #5 of 9 Old 12-19-2013, 07:38 PM
Scopez
1994 ZJ
Definitely repair your intakes plenum with the Hughes kit. Maybe do the kegger mod as well.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #6 of 9 Old 12-20-2013, 08:13 AM
HighLonesome
I was reading on another forum to never increase the engine compression without replacing the piston rings. They will break. FYI
post #7 of 9 Old 12-20-2013, 09:09 PM Thread Starter
41jeep41
2010 JK Wrangler
Ended up keeping it all stock, needed to get it back on the road sooner than I was expecting. Did end up getting a 5.9L air intake manifold and installed that since the old one ended up getting damaged. It may just be me but I swear that the motor is running smoother and that I have more power.
41jeep41 is offline
post #8 of 9 Old 12-20-2013, 09:41 PM
Scopez
1994 ZJ
Plenum is probably still good. I would've still replaced the plate with an aluminum plate...you'll be tearing into it sometime to replace that.
Scopez is offline
post #9 of 9 Old 12-21-2013, 09:56 AM Thread Starter
41jeep41
2010 JK Wrangler
I would have liked to but like I said I ended up having to get her back on the road much sooner than I expected. I will most likely open her back up this summer.
41jeep41 is offline
