5.2 performance - JeepForum.com
post #1 of 69 Old 08-22-2010, 06:46 PM Thread Starter
DieselNasty
5.2 performance
Lookin to get some extra power from my 5.2 and saw rock-it-parts has a throttle body, tb space, and cold air intake. My question is has anyone tried any of these mods and noticed any power gains? Are there any other places i can look for some performance parts for these zjs?
DieselNasty is offline
post #2 of 69 Old 08-22-2010, 07:55 PM
NJSPEEDER
Before you spend a bunch of money on parts:
1. You don't need to buy a cold air intake, just get out the dremel and cut the sides out of the air box that face away from the engine
2. Do an e-fan conversion. It gives you more control over engine temp frees up a noticeable amount of HP for a fraction of what a TB and Spacer cost
3. Do a full tune up. If you take care of any maintenance that has been ignored you will be surprised how much better the engine will run.
-Tim
Tim Mullaney
1993 Jeep Grand Cherokee Larado
1999 Chevrolet Camaro Z28
New Jersey F-Body Owners Association
NJSPEEDER is offline
post #3 of 69 Old 08-22-2010, 08:08 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
what he said^. and exhaust and tuner is the place to start, CAI only helps at or near WOT
HighLonesome is online now
post #4 of 69 Old 08-22-2010, 09:11 PM
freakinheep89
make sure you have OBDII, since some of the early 96 ZJ's were still OBDI.with OBDII you have tuners and programmers available. not so with OBDI
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 69 Old 08-22-2010, 10:24 PM Thread Starter
DieselNasty
its obdII i and hear you guys on the maintenance that is the first thing im doing. I was just curious about the tb and the intake since i couldnt find much. I have talked to Kolak already and plan on getting headers, 3in exhaust and ignition first. Maybe a reflash for the ecm later. How about the electric fan conversion who makes a nice setup?
1996 ZJ Limited 5.2
Stock so far soon to have a 5.9 and 46re! Plus lots of parts in boxes
post #6 of 69 Old 08-22-2010, 10:36 PM
freakinheep89
easiest way is to do the Taurus E fan swap. search it
TJ-
post #7 of 69 Old 08-22-2010, 11:41 PM
xgerstandtx
x4 the taurus fan is a noticeable difference.
xgerstandtx is offline
post #8 of 69 Old 08-23-2010, 01:06 AM
freakinheep89
List O' Crap to do to a 5.2
remove the 5.2
swap it for a 5.9(less machining this way)
bore the 5.9 over and make a 408 stroker
build the 408 with nice pistons, rings, heads, valves, springs, pushrods, cam, and lifters and all the other little goodies you want
put now 400hp+/- in where 5.2 was
watch the 249 transfer case commit suicide
swap in a 242.
observe as your transmission self destructs
send trans to be rebuilt
swap in a 242.
just a theory lol, didnt know if there was a budget
TJ-
post #9 of 69 Old 08-23-2010, 07:47 AM Thread Starter
DieselNasty
lol thats a nice theory i wish i was gonna spend that much on this engine what a sleeper it would be! Thanks for the fan iinfo guys.
1996 ZJ Limited 5.2
post #10 of 69 Old 08-23-2010, 10:12 AM Thread Starter
DieselNasty
ok so now i want to do the taurus fan controlled with thermostatic switches weems like a great mod
1996 ZJ Limited 5.2
post #11 of 69 Old 08-23-2010, 10:31 AM
HighLonesome
in the long run, a Welcome to Delta Current Control controller will work better and cost less than the failure prone thermoswitches
post #12 of 69 Old 08-23-2010, 11:16 AM Thread Starter
DieselNasty
yea i was looking at your write up. so your newer setup uses one of these controllers?
1996 ZJ Limited 5.2
post #13 of 69 Old 08-23-2010, 04:00 PM
SoCalDevyn
Like the others said, keeping that motor tuned up will help a lot on its own. Run a good exhaust set up and as for a tuner idk what ones actually work on these motors. Anyone got any they kno make a difference? I did the e fan swap, love it. I also have a msd coil I'm going to putting on soom for a better spark so maybe look iinto that
98 ZJ Limited 5.2, Blacked Out, 6.5" IRO Long Arm, 15x8 Pro Comp 97's, 35" MTZ's, Custom Front Bumper, Rusty's Disco's, KOR Light Bar, 8000K HID's, Magnaflow, CB, 5% Tint, System, TJ Gas Bezel, JKS Rear Trac Bar, Rusty's Front Trac Bar, KOR Stabilizer, Cold Air Intake, E-Fan, RCX Diff Guard, Clayton Brake Lines, MSD Ignition, Gen Right Louvers, Custom Sliders, IRO Belly Skid, Rigid Lights
SoCalDevyn is offline
post #14 of 69 Old 08-23-2010, 05:48 PM Thread Starter
DieselNasty
yea im going to do the e fan swap for sure and the kolak ignition comes with an msd coil so that's coming eventually. Im still curious if anyone has a diff throttle body on there v8 or who has tunig and how much did it make a difference.
1996 ZJ Limited 5.2
post #15 of 69 Old 08-24-2010, 01:17 AM
freakinheep89
i have the Hughes engines Modified V8 throttle body. $170, when i swapped to the 1.7 rockers, it needed more air, so i got the Hughes from Hughesengines.com. made a big difference in breathing over the stock, but thats cause mine draws more air now, not sure of a stock 5.2 change but its worth a shot
TJ-
wj 4.7 performance ryanwj09 ZJ Grand Cherokee Forum 4 10-15-2009 05:26 PM
performance ?'s DerekBlk06RT WK Grand Cherokee & XK Commander Forum 4 07-21-2009 03:21 PM
Pre 99 ZJ Performance ECU?? gmartin1215 ZJ Grand Cherokee Forum 1 05-02-2009 05:06 PM
Need More Performance SpeedUpCherokee ZJ Grand Cherokee Forum 17 09-21-2008 04:50 AM
performance? jason94 ZJ Grand Cherokee Forum 0 12-26-2002 11:38 PM
