5.2 Exhaust measurements - JeepForum.com
post #1 of 10 Old 07-29-2013, 08:29 PM Thread Starter
Kevinyj95
Hi all.
Im trying to order everything I will require for my exhaust. As there are no part stores with in an hour of where I am located. So Does anyone have the measurements of the stock tail pipe and y pipe? I did look it up but got conflicting answers. Thanks again.
Kevinyj95 is offline
post #2 of 10 Old 07-29-2013, 08:53 PM
newfieZJ
V8 exhaust break down 93-98
collectors off the manifold are 2.25 IIRC .
the y-pipe turns 2.5 where they meet .
convertor has 2.5 inlet/2.25 outlet
muffler has 2.25 in/2.5 out .
tailpipe is 2.5 except the 5.9 which is 3"
Stock 5.9 sitting right in front of me . I'm in my garage
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 10 Old 07-30-2013, 05:42 AM Thread Starter
Kevinyj95
Thanks a lot man. That's OD right?
post #4 of 10 Old 07-30-2013, 05:45 AM Thread Starter
Kevinyj95
Huh the tailpipe in my 5.2 and 5.9 are the same size Although the muffler on the 5.9 outlet is facing inwards towards the ds instead of towards the uniframe. Thatll confuse ya.
post #5 of 10 Old 07-30-2013, 06:26 AM
newfieZJ
Yes , OD IIRC .
Yeah , you might have confused me there . Can't say I fully understand what you are saying . the muffler should be center in , offset out . As for the tailpipe , they can be changed . I assume either your 5.2 has a 3" tailpipe installed or the 5.9 a 2.5 Got pics ? Need any ?
newfieZJ is offline
post #6 of 10 Old 07-30-2013, 07:01 AM Thread Starter
Kevinyj95
Na I got it figured out. Thanks again man. I think since im going aftermarket muffler and cat I am going to run 2.5 all the way. Take all the 2.25 out of there. Well except the manifolds. I will connect them all with 2.5 id pipe. I am also going to weld it all so I never have to deal with clamp indents again. I am thinking of finding an exhaust paint to prevent corrosion. As I live in maine there is a lot of salt on the roads in the winter.
post #7 of 10 Old 07-30-2013, 07:12 AM Thread Starter
Kevinyj95
5.2 and 5.9 or should I say whats left of the 5.2 exhaust. Looking at them now I think I will be doing them both.
post #8 of 10 Old 07-30-2013, 07:21 AM
newfieZJ
This is stock 5.9
newfieZJ is offline
post #9 of 10 Old 07-30-2013, 07:39 AM Thread Starter
Kevinyj95
Hmm that's interesting so either the 5.2 Exhaust is on incorrect or the 5.9 switched sides and has a slightly longer tail pipe. It wouldn't surprise me about my 5.2 that exhaust has been hacked up and welded back together so many times I cant even remember. Tree stumps and rocks. That's a huge cat. I wonder why the diameter changes like that. Your jeeps so clean.
post #10 of 10 Old 07-30-2013, 08:06 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
belongs in the FAQ
HighLonesome is offline
exhaust
