5.2/5.9 cracked heads - JeepForum.com
post #1 of 11 Old 10-21-2016, 12:25 AM Thread Starter
Donutjeep12
1994 ZJ
Hey guy quick question. Im in the process of getting a 5.9 ready for my 94 zj. But the machine shop called and said that the 5.9 heads are both cracked between valves on the outer set of the intake and the exhaust. So i am hoping that when i pull my 5.2 out that my heads aren't cracked and i could use them hopefully. So the question is any of you guys running on cracked heads? Did you have the shop put bigger valves in? Buy reman or aftermarket heads like EQ or eldlebrock? I just dont have the budget for a set of heads. Please let me know what you guys have done. Thank you
Donutjeep12 is offline
post #2 of 11 Old 10-21-2016, 02:41 AM
Timo_90xj
Timo_90xj's Avatar
5.2/ 5.9 quite often crack theur heads. I've seen numbers as high as over 50% of them having cracked heads at 150-200k miles. They often run ok even with cracked heads, but they are not worth fixing if they are.
Reman heads on rockauto are about 300$ per head, ir you can get better heads with bigger valves at a slightly higher price.
***Under construction***
Timo_90xj is offline
post #3 of 11 Old 10-21-2016, 07:01 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
5.9 heads crack more than 5.2 because of the extra heat. Maybe you will get lucky with your 5.2 heads.
HighLonesome is offline
post #4 of 11 Old 10-21-2016, 07:37 AM
jeepjeepster
Im sure it happens but but yet to have read about those cracks causing an issue...
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #5 of 11 Old 10-21-2016, 07:56 AM
Timo_90xj
Timo_90xj's Avatar
Like I wrote above, a lot of them crack but it usually doesn't cause issues.
But, cracked heads usually aren't worth fixing or modifying.
post #6 of 11 Old 10-21-2016, 08:35 AM Thread Starter
Donutjeep12
1994 ZJ
Thank you guys for the replys. Ill just hope that the 5.2s are not cracked. But if they are ill just save up for some reman ones. To bad they wont take 4 cores lol
post #7 of 11 Old 10-22-2016, 08:36 PM
Candymancan
Heard ratmonkey many years ago mention the 5.9 heads crack alot. But it usually doesnt cause issues. Usually... lol
Candymancan is offline
post #8 of 11 Old 10-22-2016, 09:13 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Neither my 5.2 with 225k miles or the 5.9 with 12k miles ever cracked.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #9 of 11 Old 10-22-2016, 09:15 PM
Candymancan
I wouldnt know if mine was cracked. I havent looked.. But if they were i havent had issues yet.
post #10 of 11 Old 10-24-2016, 09:03 PM
Bodybuilder21
I'll sell you my stock 5.9 heads if you're interested...dropping Edelbrock RPM's w/ Harlard Sharp roller rocker's+ Mopar Perf. valve cover's soon
98' 5.9- racejeep build (boosted 408 dreamin')
96' 4.0- 5.5"- currently torn down for 4.7 stroker
Bodybuilder21 is offline
post #11 of 11 Old 10-25-2016, 06:12 AM
Timo_90xj
Timo_90xj's Avatar
You're gonna love the Edelbrock RPMs, trust me!
I'm using Comp cams ultra pro magnum roller rockers, went with 1.6 ratio.. was thinking 1.7s which probably would've been a good idea for a bit more valve lift.
Btw., beware with the Mopar performance valve covers that they might be a tight fit. I had to lift my A/C compressor 3/8" using DIY spacers and longer mounting bolts, because compressor A/C service nipple was hitting the valve cover. Also, there was not enough room on the passenger side between the PCV valve and A/C hard line. My covers were 100% original Mopar performance covers - Jeep- ones which should be a direct fit - but nope.
