4x4 problem - JeepForum.com
post #1 of 3 Old 11-24-2003, 08:22 PM Thread Starter
GreenZJ93
GreenZJ93's Avatar
4x4 problem
I have a 93 ZJ with a 5in Pro Comp lift and when my 4wheel partime is engaged and my tranny is in reverse my jeep stalls almost immediatley after I release the brake or when I go to give it some throttle. Since the lift install I havent lowered the T-case and it is pretty sticky going into 4-Lo(grinding and what not) as well. I was wondering if my driveshaft angles are too severe even though visibly they dont look bad. Also my U-joints are fairly new and I get a nice clank after I put the tranny in reverse or drive and step on the throttle, I was wondering if this could be T-case related as well. If anyone could help me out, thanks in advance.
GreenZJ93 is offline
post #2 of 3 Old 11-25-2003, 10:21 PM
Swamp Boy
Swamp Boy's Avatar
ONly thing I can help you with is that when you shift from 4 hi to 4lo you need to be rolling about 2 or so MPH and put your gear shift in N and then quickly jerk it into 4 lo .. Do the same when shifting back slow roll shove it into 4 hi..
Mine makes some noise once in a while because the bump stop thingy drags on the coils..
Good luck with the other stuff..
Hope the shift info helps..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 3 Old 11-27-2003, 11:13 AM Thread Starter
GreenZJ93
GreenZJ93's Avatar
Yes that is How I engage my 4-lo and there is some nasty grinding still. Im stumped on this stalling problem and have been looking for my mechanic but everytime I try to find the bastard hes got an 'out to lunch' sign on his god damn door! I guess the only way to resolve this is to hunt him down!
is this a battery problem or alternator problem? Lady_Luck ZJ Grand Cherokee Forum 14 01-02-2009 08:04 AM
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 02:00 AM
Problem with the wheel staus lights on dash and head light switch problem jeep2dmax ZJ Grand Cherokee Forum 0 12-21-2007 07:34 PM
HELP! SOS! 94 GC overdrive problem-Will VSS solve problem tinker1121 ZJ Grand Cherokee Forum 1 07-15-2005 09:08 AM
'93 Starting Problem,,, PCM Problem? jeff_connors ZJ Grand Cherokee Forum 0 01-19-2004 10:53 AM
