4x4 front axle oil vs rear axle oil - JeepForum.com
post #1 of 14 Old 07-07-2009, 06:12 PM Thread Starter
sdowney717
does the front axle oil wear out considering the jeep is always in 2wd mode?
I just changed out the rear oil to mobil 1 synthetic 90w and was wondering if it was worth bothering with the front.
sdowney717 is offline
post #2 of 14 Old 07-07-2009, 06:20 PM
ZooTech
Everything is still spinning, the gears just aren't meshed together under drive tension is all. Plus, gear oil breaks down over time, not just usage. I'd change both.
~ 1995 ZJ
~ np242
~ 2.25" BB
~ Rough Country Nitro 9000 shocks
~ 31x10.5x15 Dunlop Radial Mud Rovers
~ 15x8 black Unique wheels
ZooTech is offline
post #3 of 14 Old 07-07-2009, 06:29 PM Thread Starter
sdowney717
true it spins around, but not under any heavy pressure like the rear.
I might consider doing it if you will tell me my MPG will go up when I put in synthetic gear oil.
post #4 of 14 Old 07-07-2009, 06:30 PM
ajmorell
ajmorell's Avatar
Your mileage won't go up but you'd only be doing yourself a favor if the front hasn't been changed in a while. The front might not be under any load but there is still friction present which generates the heat that breaks down the oil.
ajmorell is offline
post #5 of 14 Old 07-07-2009, 06:34 PM
ZooTech
The only thing I'm gonna tell you is that it's your Jeep and your money, pick your battles. Changing the lube is about preventative maintenance. If you don't think it's worth your time/money that's all you.
~ 1995 ZJ
~ np242
~ 2.25" BB
ZooTech is offline
post #6 of 14 Old 07-07-2009, 06:38 PM
blackjack12982
1994 ZJ
Wow, really? As someone who had to swap in a new D30 because the PO didn't do a lick of PM, I'd go ahead and recommend you doing this if you don't know when it was done last or know the condition of the fluid that's in there currently. Just my $.02, though.
blackjack12982 is offline
post #7 of 14 Old 07-08-2009, 02:46 PM Thread Starter
sdowney717
I dont know when it was done and the jeep has 186000 miles on it.
On the rear, I got rid of the leaky plastic plug.
I brazed on a 1 inch pipe threaded fitting and screwed in a recessed plug. First though I cut it down on the saw, all you need is about 3/8 inch of the cast iron pipe fitting. I was too cheap to go buy another leaky plastic plug. I took off the cover to drain it and have a look at the gears. Cleaned all the rust off and epoxied it and the shot it wit black paint. It looks great and is highly functional.
post #8 of 14 Old 07-08-2009, 03:32 PM
the88thpianoman
2003 WJ
If you want to grenade your front axle by leaving the same gear oil in for another 186k miles because you're "too cheap" to do the most basic maintenance, go for it. Just don't expect to have a working Jeep for very long.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #9 of 14 Old 07-09-2009, 07:43 AM Thread Starter
sdowney717
well I pulled the plug out and the fluid is clear and oily not black not dirty.
does anyone know if gear oils shear down with age, do they get thicker or thinner? the oil in there seems perfect. It is so clean looking I am thinking it must have been changed. But of course it never is under any real loading is it.
post #10 of 14 Old 07-09-2009, 07:47 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Yea, thats all there is to it right there.
Chrysler recommends changing diff fluid every 12k-30k miles
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #11 of 14 Old 07-09-2009, 09:00 AM
SnowLeopard
I'm trying to wait until I can afford some True-tracs and 4.10 gearing. I'm not in a position to do the diffs myself so I really don't want to pay $100 to have the fluid changed. I suppose preventative maintenance would be worth it though. It might not be that expensive after all...I don't know.
SnowLeopard is offline
post #12 of 14 Old 07-09-2009, 10:29 AM
ajmorell
ajmorell's Avatar
The difference in technical knowledge/time spent between those two chores isn't even comparable. All you need to do a fluid change is a tube of RTV, basic sockets or wrenches, somewhere to drain the fluid and something to fill it back up (something as simple as a turkey baster works just fine).
ajmorell is offline
post #13 of 14 Old 07-09-2009, 10:43 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Well if you say it won't wear down because it isn't "under any real loading" then you know best and there is no need to change it. What is the question then?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #14 of 14 Old 07-09-2009, 10:45 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Yea, when in doubt ALWAYS do that maintenance dude (OP)
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 08:47 PM
changing front axle shaft..axle nut lakailimited06 ZJ Grand Cherokee Forum 2 06-14-2009 08:40 AM
93 and 96 Front and Rear Axle Compatiable? contender ZJ Grand Cherokee Forum 4 04-06-2009 07:59 PM
Does the build sheet say if you have a open rear axle or ls axle? Aussi locker bjl95mustang ZJ Grand Cherokee Forum 28 04-06-2009 07:09 PM
locking one axle only -- front or rear? MEinSoCal ZJ Grand Cherokee Forum 16 08-07-2008 10:28 AM
