4WD Shifter Question - Page 2 - JeepForum.com
post #16 of 23 Old 07-15-2011, 07:46 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
its tough to move, I use medium size channellocks...plenty of persuasion
put the trans in N and try it
you could tighten the nut and move it with the shifter to N
maybe it is stuck
HighLonesome is online now
post #17 of 23 Old 07-16-2011, 10:41 AM
HighLonesome
Originally Posted by VolcomPunk View Post
you would think moving the TC lever to the front of the jeep would be the 2HI
I went and checked and you are right.
post #18 of 23 Old 07-16-2011, 11:06 AM
Foundrydude
block the tires when playing with the tfer case linkage.
Foundrydude is offline
post #19 of 23 Old 07-16-2011, 11:19 AM
TewSmooth18
i had to use a hammer to beat the thing lose after getting the bolt lose. probably wasent the smartest thing to do but it worked
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
post #20 of 23 Old 07-19-2011, 10:33 PM Thread Starter
VolcomPunk
trust me i do haha
i still havent had any luck moving that damn thing...and i know its not stuck when i move the transfer lever in the cab to N the lil tab moves as well which still confuses me as to how or why the linkage would need to be adjusted, but none the less it is something i will continue to work on since i cant exactly drive it at this current time
Green Jeep #337
WakeUpNow
R.I.P. Ratmonkey...Your now wheelin with the angels
VolcomPunk is offline
post #21 of 23 Old 07-20-2011, 07:44 AM
HighLonesome
It may not need adjusted, but you need to make sure of the basics before you go ripping into your transfer case.
post #22 of 23 Old 07-20-2011, 08:15 AM
Foundrydude
Put the tranny in neutral and have somebody rock the jeep back n forth while you try to move the linkage. Be absolutely sure neither end of the case is bound up
post #23 of 23 Old 07-20-2011, 09:42 PM Thread Starter
VolcomPunk
i aint that skilled to go ripping into my TC. plus the only way i would even begin to break down my Jeep and really start to learn stuff bout it is if A) it wasnt my daily driver B) i actually had the proper tools and place to do the work
Green Jeep #337
WakeUpNow
249>242 transfer case shifter/shifter bezel questions?? kmd1776 ZJ Grand Cherokee Forum 19 03-26-2011 04:07 PM
question about shifter cable zjinprogress ZJ Grand Cherokee Forum 0 12-04-2010 05:51 PM
05 manual matic shifter question mattman0o0o WK Grand Cherokee & XK Commander Forum 1 10-29-2010 07:15 PM
tcase shifter knob question sappi285 ZJ Grand Cherokee Forum 2 06-19-2010 07:35 PM
WJ SelecTrac Shifter Question ptochman ZJ Grand Cherokee Forum 2 01-17-2007 05:15 PM
