4WD Shifter Question - JeepForum.com
post #1 of 23 Old 07-12-2011, 09:45 PM Thread Starter
VolcomPunk
I got a 95ZJ stock...other than the exhaust. My issue is when i go to shift into 4-part time it goes into 4-part time, when i shift it into N it it stays in 4 part-time and when i shift it to 4-Lo well it stays in 4 part-time. I feel it may have something to do with my linkage but im not to sure. anyone have this issue before or may know what it could be? any input is greatly appreciated.
Green Jeep #337
WakeUpNow
R.I.P. Ratmonkey...Your now wheelin with the angels
VolcomPunk is offline
post #2 of 23 Old 07-12-2011, 09:47 PM
Corrupt
Sounds like time for a linkage adjustment.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #3 of 23 Old 07-12-2011, 09:49 PM Thread Starter
VolcomPunk
yea i was afraid of that
Green Jeep #337
WakeUpNow
post #4 of 23 Old 07-12-2011, 10:07 PM Thread Starter
VolcomPunk
another question...now that i know what the issue is...how do i go about adjusting the linkage...im not exactly mechanically inclined but i would love to learn how to do this stuff not only to save money on labor but so if it happens again or if a friend has the same issue.
Green Jeep #337
WakeUpNow
post #5 of 23 Old 07-12-2011, 10:23 PM
TewSmooth18
Just get under your jeep and look at the transfer case (attached to the tranny), look for the shift lever that has a bar (shift linkage) attached to it, you will see the bar sliding through a thing with a bolt through it, losen that bolt (it's a size 13mm) (you will probably need some PB Blaster to get it lose and for the linkgage to slide through it freely). once you have it lose, move the shifter all the way forward to 2wd and then move the lever manually on the transfer case to 2wd (check your VIC to make sure it shows that it's in 2wd). once it shows that, tighten the bolt up and then shift through all the gears to make sure it's shifting into all the gears and they display correctly
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
post #6 of 23 Old 07-12-2011, 10:26 PM Thread Starter
VolcomPunk
alright cool...sounds like a something to do on thursday
Green Jeep #337
WakeUpNow
post #7 of 23 Old 07-14-2011, 12:50 PM Thread Starter
VolcomPunk
ok so i got under and i got the bolt loosened with ease of no PB Blaster i am however letting the linkage soak in it for a lil...now while its doin that...how will i know if the linkage is all the way in 2WD drive? will the rod juss stop goin forward or what?
Green Jeep #337
WakeUpNow
post #8 of 23 Old 07-14-2011, 01:47 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The way to do it is turn the lever on the TC to Neutral with channellocks, then set the shifter to neutral and lastly tighten the cinching bolt on the linkage.
HighLonesome is offline
post #9 of 23 Old 07-14-2011, 01:54 PM Thread Starter
VolcomPunk
ok and where is this lever on the TC....im not a very mechanically inclined and tryin to figure out where everything is on my own without knowing what it looks like makes it a lil more difficult for me...i know where the clinching bolt and linkage is. now is the lever for the TC connected to that in some way?
Green Jeep #337
WakeUpNow
post #10 of 23 Old 07-14-2011, 02:07 PM
HighLonesome
follow the linkage back to the TC, the linkage terminates at the lever
the lever is rectangular metal, the linkage goes to a hole in the lever
post #11 of 23 Old 07-14-2011, 02:29 PM Thread Starter
VolcomPunk
Im assuming your talkin bout the part circled in red?
Green Jeep #337
WakeUpNow
post #12 of 23 Old 07-14-2011, 02:29 PM Thread Starter
VolcomPunk
and if you are how will i be able to tell its in Neutral
Green Jeep #337
WakeUpNow
post #13 of 23 Old 07-14-2011, 02:41 PM
HighLonesome
yep thats it
First be sure the cinch bolt is loose. Then move the TC lever completely to one end using pliers. That will be 4lo or 2hi (sorry can't remember which one, I think moving it toward the rear of the jeep is 2hi. The move it and count the detent positions. Since you have 2hi, 4lo, 4high, N, the setting will be one of the middle detents. Then if you start it up and can't move, you got N
post #14 of 23 Old 07-14-2011, 02:54 PM Thread Starter
VolcomPunk
ight sounds good...thanks for the help. sadly it has now started storming so i cant get back under today
on a side note though...you would think moving the TC lever to the front of the jeep would be the 2HI
Green Jeep #337
WakeUpNow
post #15 of 23 Old 07-14-2011, 06:52 PM Thread Starter
VolcomPunk
ok i got back under there and i could not for the life of me get that metal bracket to budge - FAILED prob doesnt help that i dont have a great deal of room under there to get a great grip on it to move it.
Green Jeep #337
WakeUpNow
249>242 transfer case shifter/shifter bezel questions?? kmd1776 ZJ Grand Cherokee Forum 19 03-26-2011 04:07 PM
question about shifter cable zjinprogress ZJ Grand Cherokee Forum 0 12-04-2010 05:51 PM
05 manual matic shifter question mattman0o0o WK Grand Cherokee & XK Commander Forum 1 10-29-2010 07:15 PM
tcase shifter knob question sappi285 ZJ Grand Cherokee Forum 2 06-19-2010 07:35 PM
WJ SelecTrac Shifter Question ptochman ZJ Grand Cherokee Forum 2 01-17-2007 05:15 PM
