4WD to 2WD Conversion - JeepForum.com
post #1 of 37 Old 12-07-2005, 08:40 PM Thread Starter
4greenes
I recently bought a 1995 Jeep GC Orvis with the 5.2L engine and a piece of junk 249 transfer case. My research has shown that the 249 TC are a common problem, frequently go bad, and are very pricey to rebuild/replace. A local junk yard has a 1993 2WD Dodge truck with a 5.2L engine. The junk yard also has a 1994 Jeep GC 2WD front axle ( Jeep did not make any 1995 GC 5.2L with 2WD). Since my Jeep GC and the Dodge truck both have the same 318cc (5.2L) engines, I want to convert my GC to 2WD. Does anyone know if the computer system will work? Has anyone done a conversion like this? Any info would be appreciated.
4greenes is offline
post #2 of 37 Old 12-07-2005, 08:42 PM
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
Why oh Why would you do something like that!!?!?!?! Instead you should just find an NP 231 or NP 242 Transfer case (usually found mated to I6's) Then you have 2wd as an option, but have 4wd when you need it.
Eric
RAAB3485 is offline
post #3 of 37 Old 12-07-2005, 08:43 PM
Dana44
Don't make it 2x4, get a diffrent T-case..
Dana44 is offline
post #4 of 37 Old 12-07-2005, 08:45 PM
RAAB3485
RAAB3485's Avatar
It'll be much less work anyways.
Eric
RAAB3485 is offline
post #5 of 37 Old 12-07-2005, 08:48 PM
grandman17
t-case swap wayyy easier and mabey cheaper depending on how you do things
grandman17 is offline
post #6 of 37 Old 12-07-2005, 08:49 PM
RAAB3485
RAAB3485's Avatar
Plus, you wouldn't get any better gas mileage converting to 2wd if that was a consideration of yours.
Eric
RAAB3485 is offline
post #7 of 37 Old 12-07-2005, 08:56 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Plus resale will be higher with 4x4 over 4x2
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #8 of 37 Old 12-07-2005, 09:00 PM
ktmracer419
ktmracer419's Avatar
1997 XJ Cherokee
[QUOTE=4greenes] 1994 Jeep GC 2WD front axle [QUOTE]
since when did they start making front axles for 2wd vehicles?
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline
post #9 of 37 Old 12-07-2005, 09:01 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
No one wants a 2WD GC. It'll be worth nothing! Swap in a 242 and be done with it! Many of us have done it. There's write ups on here - just use the search function - 249 to 242 swap!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #10 of 37 Old 12-07-2005, 09:05 PM
ArloGuthroJeep
Mr. Hyde!
Phil
Ok Phil gonna give you a hard time here...ever search for "249 to 242 swap" via the search function...you get this back:
Originally Posted by StupidSearchFunctionLimitations
The following words are either very common, too long, or too short and were not included in your search: 249, to, 242
I hate how it has short word/common word limitations...makes it difficult to search for the most common problems which is why we hear about them so often.
post #11 of 37 Old 12-07-2005, 09:08 PM
RAAB3485
RAAB3485's Avatar
Use wildcards. (*) then it will work.
Heres what I got when I did that http://www.jeepforum.com/forum/searc...earchid=270698
Eric
RAAB3485 is offline
post #12 of 37 Old 12-07-2005, 09:11 PM
ArloGuthroJeep
Mr. Hyde!
When I am trying to give Phil a hard time I don't need you to call me out on it Never knew about wild cards on the searches...
http://www.jeepforum.com/forum/showt...ht=%2A242+swap
post #13 of 37 Old 12-07-2005, 09:11 PM
Phil Gerard
Former Mod
OK - Do "Transfer Case Swap" and you'll get all these threads!
http://www.jeepforum.com/forum/searc...earchid=270696
Phil
post #14 of 37 Old 12-07-2005, 09:13 PM
RAAB3485
RAAB3485's Avatar
Eh, its the least I can do for you always out posting me.
Eric
RAAB3485 is offline
post #15 of 37 Old 12-07-2005, 09:15 PM
Phil Gerard
Former Mod
How do you use a wildcard exactly?
Phil
4wd conversion ????'s jeepfever83 ZJ Grand Cherokee Forum 9 01-20-2011 01:22 PM
E85 conversion RKOTAREK ZJ Grand Cherokee Forum 7 12-25-2009 07:47 PM
E-85 Conversion bbanger WK Grand Cherokee & XK Commander Forum 4 10-11-2009 10:30 AM
RB1 conversion Johnyakimo1855 ZJ Grand Cherokee Forum 7 11-29-2008 03:45 PM
ZJ Conversion: 2WD to 4WD REDLYNER ZJ Grand Cherokee Forum 4 10-27-2007 06:48 PM
