46rh transmission - JeepForum.com
post #1 of 8 Old 02-12-2010, 02:18 PM Thread Starter
james613
46rh transmission
i have 97 zj 5.2 with 44re and 249, vc is toast, i am wanting to swap in a 242 and a 46rh out of a 93 zj.(one tranny is hydrolic and one is electronic?)
anyone done this swap?
james613 is offline
post #2 of 8 Old 02-12-2010, 08:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you need a tcm for the 46rh, it is NOT fully hydraulic.
a 46re is a simple bolt in swap.
ratmonkey is offline
post #3 of 8 Old 02-12-2010, 08:12 PM Thread Starter
james613
besides the tcm what other mods would have to be done?
have you done this swap?
wiring hookups..?
thanks
james613 is offline
post #4 of 8 Old 02-12-2010, 10:17 PM
JrMechanic
You will need the driveshafts from the 93, the 46RH is longer.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #5 of 8 Old 02-12-2010, 11:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Ok. You will have a constant check engine light on. The 46rh is standalone but you'll need to do some wire harness splicing tp get it driveable.
You will need the flexplate from an early v8 as the torque converter bolt pattern changed in 96.
You will need the early grand cherokee tranny Crossmember as the mounts are different. You will need new driveshafts as the rh is longer and the 44a pinion is longer too. So no stock will fit. Same for front shaft as early grands had the long pinion d30.
Get a 46re from a niner. You'll only have to deal with the driveshaft then(and probably not because the rh is only longer due to the mech governor on the od unit.)
post #6 of 8 Old 02-13-2010, 08:35 AM Thread Starter
james613
check engine light... can this be solved by swappoing the computers...?
has this swap been done by anyone?
james613 is offline
post #7 of 8 Old 02-13-2010, 11:44 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
nope, you can't swap computers without swapping EVERYTHING front of the driver's seat for wiring, sensors, and emissions. including the gauge cluster which means the dash too.
stick to obdii controlled systems, if you want a junkyard upgrade, the 46re from a jeep 5.9 limited is as close to bolt in as you'll get. if you just want a stronger tranny have it rebuilt with better clutches, 48re spec OD unit, and a shift improver kit.
post #8 of 8 Old 02-13-2010, 01:06 PM Thread Starter
james613
do you know if the front half of the 46rh would bolt up the the rear half of the 44re?
james613 is offline
93 ZJ (46RH): What is the best/easiest transmission conversion? ninethreezj ZJ Grand Cherokee Forum 30 01-18-2012 12:46 PM
Transmission swapping, 44RE for a 46RH Brucebcd ZJ Grand Cherokee Forum 4 03-21-2011 04:36 PM
46RH Transmission Change CBrowning84 ZJ Grand Cherokee Forum 7 01-08-2010 09:19 PM
46RH Transmission Weight? Ray41147 ZJ Grand Cherokee Forum 7 01-03-2010 12:47 PM
Need info on transmission donor, 46RH hambubba ZJ Grand Cherokee Forum 6 01-25-2007 10:35 PM
