46RH Trans in 1996 ZJ? - JeepForum.com
post #1 of 9 Old 03-17-2014, 04:27 PM Thread Starter
MarkRZ
I have a 1996 ZJ Limited with 162,000 miles. It will drive for about a mile and then won't move in any gear. Looked at the trans model and first two letters are RH. I thought 1996 through 1998 models came with 44RE. Is it possible that a 1995 model trans (46RH) was installed in my 1996 at factory?
Will a bad governor pressure solenoid and sensor be a possible cause of my problem?
MarkRZ is offline
post #2 of 9 Old 03-17-2014, 04:44 PM
CatSplat
1994 ZJ
Where are you seeing "RH" as the trans model? You are correct to assume that it should be a 44RE and that a 46RH being installed would be extremely unlikely in a 1996.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #3 of 9 Old 03-17-2014, 05:17 PM
PolkaPower
No, and a 46rh is hydraulic so it doesn't have a gov trans solenoid.
PolkaPower is offline
post #4 of 9 Old 03-17-2014, 08:25 PM Thread Starter
MarkRZ
The number on the drivers side of trans which lists part no., build date and serial number. I apologize, I misread, ID is: PK521191082600 8856
MarkRZ is offline
post #5 of 9 Old 03-17-2014, 08:50 PM
CatSplat
1994 ZJ
Originally Posted by MarkRZ View Post
ID is: PK 52119108 2600 8856
Yup, 52119108 is the part number for a 44RE. No transmission swap shenanigans here!
The Jeep of Theseus
CatSplat is offline
post #6 of 9 Old 03-18-2014, 05:44 AM Thread Starter
MarkRZ
Would there be any issues with installing a 1998 trans that had a 5.2L. Would the electronics be same?
MarkRZ is offline
post #7 of 9 Old 03-18-2014, 06:39 AM
tucsonzj
If it's the same build should be fine. So 44 re is what you have now. Get another 44re and you're good
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #8 of 9 Old 03-18-2014, 08:58 PM Thread Starter
MarkRZ
Checked the codes and have P0740 which is torque converter. Is the TC solenoid valve accessible if pan is removed? Is it advisable to change this valve and see if trans is salvageable?
MarkRZ is offline
post #9 of 9 Old 03-20-2014, 08:30 PM Thread Starter
MarkRZ
What rebuild kits are recommended for 44RE? Is TransGo shift kit the way to go also?
MarkRZ is offline
