Jeep Enthusiast Forums banner
46rh OD Solenoid
3K views 6 replies 5 participants last post by  Duffman2613
#1 ·
I am about to replace my od solenoid and my question is, arent overdrive and the tc lockup controlled by the same solenoid? If so, then my solenoid wouldnt need to be replaced cause the tc still locks up. Unless there are two seperate contacts on the one piece.
#5 ·
The overdrive and lock up solenoid are two different solenoids, but they are mounted as one piece so you are forced to replace both at the same time.
#6 ·
I was talking with a friend today about your last thread. I had completly forgotten od is solenoid operated. 2 3 are band driven. Ive been told you can test the solenoid itself by useing an ohm meter on the pcm/ecu harness which three wires and specs you will have to look up.
Top
