46rh not shifting into overdrive - JeepForum.com
post #1 of 5 Old 06-17-2011, 12:30 PM Thread Starter
Mimi4681
I have a '93 Jeep Grand Cherokee 5.2 V8. I just replaced the original transmission with a 46rh with 120,000 miles on it. It is shifting fine, however overdrive is not kicking in. Its still running at 2500 RPM around 50 mph. I had a friend put the transmission in and he is clueless as to why this is happening. All the fluids are fine. Any opinions?
Mimi4681 is offline
post #2 of 5 Old 06-17-2011, 02:02 PM
Glasssplinter
1994 ZJ
Have you tried adjusting the TV cable yet?
http://www.google.com/url?sa=t&sourc...389XZQ&cad=rja
'94 ZJ, 4.0L, 231 TC
Icom V-8000 with 1/4 wave
Glasssplinter is offline
post #3 of 5 Old 06-17-2011, 03:50 PM
Foundrydude
Does your speedometer work?
Foundrydude is offline
post #4 of 5 Old 06-18-2011, 08:09 AM Thread Starter
Mimi4681
Well, the OD decided to kick in on my way home from work yesterday. Weird, but hopefully its here to stay.
Mimi4681 is offline
post #5 of 5 Old 06-18-2011, 06:32 PM
rlcii77
What about the brake light switch, down by the pedal? I thought I read somewhere that this could cause the overdrive to disengage & make the cruise control inoperable.
I had the OD disengage on my ZJ last night on the way home. It started when I hit the highway. It would engage, then disengage. I wiggled the brake pedal with my foot while it was out of OD & it engaged again.
My cruise also doesn't work. I'm going to purchase a switch & hopefully it solves both issues. I'll keep you posted.
rlcii77 is offline
46RH slipping from 1st to 2nd, shifting kinda firm otherwise? RED-85-Z51 ZJ Grand Cherokee Forum 1 02-18-2011 03:57 AM
46rh Overdrive Problem 94ZJ-318 ZJ Grand Cherokee Forum 1 01-09-2011 06:59 PM
46RH weird overdrive problem. tednelson83 ZJ Grand Cherokee Forum 6 04-27-2010 01:43 PM
95 jeep limitied 5.2 with the heavy duty 46rh losing overdrive... 95blackie ZJ Grand Cherokee Forum 2 10-24-2009 08:52 AM
46RH overdrive button? BFI ZJ Grand Cherokee Forum 4 08-06-2008 07:56 PM
