46RH compatibility - swap for ? - JeepForum.com
post #1 of 10 Old 09-05-2006, 03:17 PM Thread Starter
RT8827
RT8827's Avatar
Hey, guys. I'm buying a 5.2L engine & 46RH tranny from a '94 ZJ. I'll be putting the V8 into my YJ Wrangler with an NV3500 manual tranny. Since I won't be using the 46RH, I'd like to know if it can be used in anything besides '93-'95 ZJs with 5.2L engine? For example, could it be used as a replacement for 42RE in 6cyl ZJs, or in Dodge trucks? I'd like to know its compatibility before I advertise it for sale.
Thanks!
Just like my Jeep hat says: "Life is good... do what you like, like what you do."
RT8827 is offline
post #2 of 10 Old 09-08-2006, 04:09 PM Thread Starter
RT8827
RT8827's Avatar
Does anyone know if the 46RH tranny from a '94 ZJ is a bolt in swap for anything besides '93-'95 ZJ V8s (5.2L)?
RT8827 is offline
post #3 of 10 Old 09-08-2006, 05:33 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
It will not work for a 4.0L.
It will work for OBD I computer engines: 3.9L V6 and 5.2L and 5.9L V8.
Is your YJ going to be built for trails or street?
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #4 of 10 Old 09-08-2006, 08:29 PM Thread Starter
RT8827
RT8827's Avatar
Thanks for the info, Tim. That's what I was looking for!
The YJ I'm building will primarily be set up for trail use (rock crawling). I do want it to be street-legal, though. I'll say 25% street use, 75% off-road. It definitely won't be a DD.
RT8827 is offline
post #5 of 10 Old 09-09-2006, 08:39 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
If you are going to be primarily on rocks, I would look to a different tranny than the NV3500 if it is not to late. The NP435 would suit you better. Especially since it won't be a DD.
The NP435 was behind the FI 5.2L/5.9L from 88-91, so you can use a stock bellhousing to mate them.
Might want to check it out
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #6 of 10 Old 09-09-2006, 09:04 AM Thread Starter
RT8827
RT8827's Avatar
Thanks for the input, Tim. If it weren't too late, I would heed your advice and go with the NP435 and get the low-range 1st gear. I have owned the NV3500 for almost a year, though, and it's one reason I decided to go with a Dodge V8 instead of SBC. My NV3500 came out of a '99 Ram 1500 and has about 40K miles on it. It has the integrated bellhousing that will bolt up to the 5.2L V8.
In order to get a better crawl ratio, I may end up putting a 4:1 TeraLow kit into the NP231. But I'll worry about that later.
Thanks, again!
RT8827 is offline
post #7 of 10 Old 09-12-2006, 05:24 PM Thread Starter
RT8827
RT8827's Avatar
46RH behind a Dodge 273?
Hey, Tim. If the 46RH will bolt up to the 318/5.2L and 360/5.9L, would it also bolt up to an older Dodge 273 V8? I found a guy who wants to put my 46RH behind his 273, along with a Dana 300 xfer case. Any idea if this would work? If not, where should I check? I've done some Internet searches, but have come up empty.
RT8827 is offline
post #8 of 10 Old 09-12-2006, 07:05 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
I really have no clue... I'll see if I can do some research on it.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #9 of 10 Old 09-12-2006, 07:56 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
273, 318, 340 & 360 all share the same bellhousing bolt pattern.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #10 of 10 Old 09-12-2006, 09:26 PM Thread Starter
RT8827
RT8827's Avatar
Thanks, Tim, for your offer to assist. Please don't worry about doing research on this for me, though... unless you're curious.
Thanks, RSL, for the confirmation on the b/h bolt pattern.
RT8827 is offline
42re to 46rh swap jhotrod83 ZJ Grand Cherokee Forum 12 06-23-2014 04:41 PM
46RH swap BlackDaddyZJ ZJ Grand Cherokee Forum 3 01-28-2010 08:31 AM
46rh help. FI Car Audio ZJ Grand Cherokee Forum 1 01-19-2009 11:12 PM
Noisy Rear Diff Swap Compatibility Question bigjpstr ZJ Grand Cherokee Forum 7 07-16-2008 07:57 PM
Jeep/Dodge/Auto/Manual transfer case swap compatibility? Aceladriver ZJ Grand Cherokee Forum 12 08-13-2007 07:04 PM
