46rh - JeepForum.com
post #1 of 5 Old 06-23-2007, 01:46 PM Thread Starter
shashank
46rh
ZJ 5.2 46RH with 142K miles. I was wondering if someone could tell me how reliable this transmission is beyond 150K.
It has started leaking at the joint where it meets the tranny case. anyone know how to fix this leak? I have not had any problems with shifts so far. it seems to be fairly smooth. I changed fluid and filter 10K miles ago and the fluid is in fair condition- no bubbles, still bright pink and strong smell and such.
what would be some symptoms of tanny going bad? wat else can i do to make it last for a while? how can i fix that (seal?) leak?
any suggestions would be greatly appreciated... and what is the best way to post pics in here? photobucket link or can i upload pictures direct in the forums?
thanks in advance
shashank
1999 WJ Limited
4.7 V8 Full time 4WD 134K & running All Stock
45RFE
Quadra Drive
Vari Lok's Both Front and Rear
shashank is offline
post #2 of 5 Old 06-23-2007, 01:56 PM
sand zj
sand zj's Avatar
Please use the search feature of the page. This subject has been done to death.
Dan
Dan
If you don't get stuck, keep trying!
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline
post #3 of 5 Old 06-23-2007, 11:29 PM Thread Starter
shashank
.. sorry i was looking for an easy way out....thanks... i will use it now.....
Shashank
i guess moderator can close this thread
1999 WJ Limited
45RFE
Quadra Drive
shashank is offline
post #4 of 5 Old 06-23-2007, 11:56 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
ah screw the search
Its the rear tranny seal. $11 at Napa. The transfer case needs to come out.
At your mileage, there is a chance that something caused that seal to fail.
HighLonesome is offline
post #5 of 5 Old 06-24-2007, 10:11 AM Thread Starter
shashank
thanks for the reply five nien.
do you know of any writeups on here about replacing the rear tranny seal? what could have caused it and what kinda problems can i expect in the future? does it need immediate replacement or will i be fine..if i keep watching tranny fluid levels?
also, i am a little confused, (since this is leaking at the seal)......is this fluid leaking out of transmission or is it leaking out of the transfer case? in other words...do i need to check fluid levels in the tranny case?(drain/fill)
thanks
1999 WJ Limited
45RFE
Quadra Drive
shashank is offline
1993 ZJ is AW4 or 46RH? wickerham ZJ Grand Cherokee Forum 3 10-27-2009 10:19 PM
46rh behind a 4.0l LordHobbit ZJ Grand Cherokee Forum 2 10-01-2009 08:15 PM
46rh help. FI Car Audio ZJ Grand Cherokee Forum 1 01-19-2009 11:12 PM
dana 300 behind a 46rh BLU88 ZJ Grand Cherokee Forum 8 03-20-2008 06:03 PM
Where is the breather on a 46RH? HighLonesome ZJ Grand Cherokee Forum 6 08-28-2007 08:48 PM
