46re Tutorial - Page 8 - JeepForum.com
post #106 of 129 Old 09-25-2012, 11:25 AM
jlipka98zj
Baxy, need your help man! Rather than clogging up your thread, thought I would start my own: http://www.jeepforum.com/forum/f13/4...eeded-1420964/
'98 5.9 Limited - Got some stuff done to it...
jlipka98zj is offline
post #107 of 129 Old 10-12-2012, 08:21 AM
jlipka98zj
Originally Posted by baxy View Post
high wear area this retianer can be replaced with a higher quality one made by SONNAX
Just finished my rebuild. Something to add to this. My retainer was fried in the area he spoke of. Be warned, if your retainer is hosed like mine, you probably need a new low/reverse drum, too. The inner diameter of said drum rides on the surface of this retainer.
post #108 of 129 Old 01-02-2013, 07:21 PM
Snowfan2
Fantastic thread!
Snowfan2 is offline
post #109 of 129 Old 11-20-2013, 05:13 PM
maverick971
I know this is an old thread but I just wanted to state that after reading this I tackled my own 46RE and am pretty happy with the results. (I should have replaced the governor I think it is causing the minor issue I'm having.) I have never attempted a transmission before and I was actually surprised how easy they are. Thank you thank you thank you.
maverick971 is offline
post #110 of 129 Old 11-21-2013, 08:05 AM
KJK
How did you deal with that giant forward clutch apply spring? Did you improvise a special tool?
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #111 of 129 Old 11-22-2013, 12:08 PM
maverick971
Are you referring to the one in the OD section. If so I have a friend that owns a transmission shop so I had him do the OD section. I did the 3 speed.
post #112 of 129 Old 11-30-2013, 01:30 PM
1slo_camaro
Great write up but I need help on what parts to buy, I have a thread started and If anyone could chime in and throw in some advice I would really really REALLY appreciate it! I am getting my 42re rebuilt but need to buy the parts and need to get the right rebuild kit that has EVERYTHING and where to buy/upgrade the insides etc....
Baxy can you please PM me. Or anyone else that is transmission savy or post in my thread please.
http://www.jeepforum.com/forum/f13/4...dvice-1842002/
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #113 of 129 Old 01-01-2014, 04:14 PM
oldguywtruck
wanted to update and add some input ,so far i have 23,000 miles on my 46re repairs and she still works ,.....since i put it back in>
....i added a trans cooler plumbed parellel to origanal ,i'm a scarap hauler and haul weight everyday over mountans ,in the summer it really helps with controlling temps ,but in the winter i have to cover it to keep temps up during non hauling normal driving
....i had a torque converter hum and a slight leak at the hub ,i checked and repositioned the aftermarket converter a little closer with some washers ,resoved issues
....a brought the borg warner heavyduty control valve soliniod and a new temp sencor thingy ,forgot the official name ,the one that controls oil flow....it was sightly sticking in second gear when i stopped ,better valve resolved issue
......hope the input helps any future novices and thank jeep furum and baxy for the valueble and informative article
oldguywtruck is offline
post #114 of 129 Old 01-13-2014, 11:53 AM
rdunk19
How many total check ball in valve body
So I curious how many check balls their are in a 46RE valve body I have read 6 of 1/4 plastic, 1 of 11/32 plastic and 1 like 1/8 or 1/16 metal. So I am trying to make sure I have them all after a spill
rdunk19 is offline
post #115 of 129 Old 01-13-2014, 11:57 AM
rdunk19
How many check balls
I am not sure also where exactly the metal one goes within the valve body plates
rdunk19 is offline
post #116 of 129 Old 01-13-2014, 01:45 PM
KJK
There are checkball pics and info. in this thread.
See post #23 Pics 6,7,8,and 10.
See post #25 Pic 9.
See post #27 Pics 9 and 13.
KJK is offline
post #117 of 129 Old 03-03-2014, 08:34 AM
Marcos
picture of shim for setting the lube for the OD unit if you change shafts make sure you transfer over this shim it makes sure the lube holes in the shaft are aligned properly in the OD unit **VERY IMPORTANT ***
What if you're swapping in another OD unit, but keeping your same main case and intermediate shaft? Will it be ok to just re-use the existing spacer or does it need to be measured for the new case?
There are a few tips out there for determining the OD piston spacer selection without all the special tools, but I haven't seen any for the Intermediate shaft spacer.
Marcos is offline
post #118 of 129 Old 05-26-2014, 12:10 AM
Filin
starting with the inner diamete work the lip gently until it is started
On automatic 46rh not work 4 speed, I heard there is an overdrive unit in the oil seal, which may be the reason
Please show this oil seal on the photo
and his number
Filin is offline
post #119 of 129 Old 02-11-2015, 03:35 AM
scepter_kz
Hi!
To me advised to ask you as expert!
I set transmission 46RE 1998/5.9L
beginning repair of transmission I saw the set valve
body of 1993, valve body differs from OEM of 1998 not much!
whether will be I have problems with my transmission!!??
scepter_kz is offline
post #120 of 129 Old 02-12-2015, 04:10 PM
CatSplat
1994 ZJ
Hey guys, I was kinda wondering why baxy (OP) had kinda disappeared after posting such a great thread and wasn't answering any PMs either. I decided to see if I could track him down elsewhere (I was hoping I could hire him to rebuild a spare trans for me) and unfortunately I came across his obituary - it looks like he passed away in late 2012. He used the same username on a few sites and his email address and location matched up with the obituary.
http://www.thefreepress.ca/mobile/obits/?id=10001348
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
NP242 tutorial baxy ZJ Grand Cherokee Forum 84 05-04-2014 09:41 AM
46re in a 5.2 shdybrady19 ZJ Grand Cherokee Forum 4 10-09-2009 05:39 AM
WJ T-Case Swap? 247 -> 242 Tutorial? hfourxzeror ZJ Grand Cherokee Forum 4 09-25-2009 02:22 PM
46re? Travis873o ZJ Grand Cherokee Forum 4 08-03-2009 01:12 PM
tutorial for ecu replacement? 94GC52 ZJ Grand Cherokee Forum 3 01-30-2009 03:28 PM
