46RE Relay ? - JeepForum.com
post #1 of 4 Old 05-07-2013, 04:27 AM Thread Starter
elmoe
46RE Relay ?
What should be the voltage to pin 1 of the transmission main plug coming from the relay output blue wire? When should voltage be present? Thanks!!
elmoe is offline
post #2 of 4 Old 05-07-2013, 05:11 AM
KoreaZJ
1994 ZJ
PCM controls Transmission Control Relay, steady +12v out on LB wire.
PCM controls solenoids on the ground side.
KoreaZJ is offline
post #3 of 4 Old 05-07-2013, 07:39 AM Thread Starter
elmoe
Thanks I need to find the pin for it. Im using a Ram PCM so the pins might be different.
elmoe is offline
post #4 of 4 Old 05-07-2013, 07:45 PM Thread Starter
elmoe
It helps when you actually have 12v at the relay. No more transmission codes!!!!!
elmoe is offline
