46re ? - JeepForum.com
post #1 of 8 Old 05-14-2013, 03:06 PM Thread Starter
BuzzZJ9er
46re ?
I bought a niner and was told it needed a new trans. The fluid was burnt and low. It also made a strange noise. My father in law added some additive and the noise went away. He said it went good.
The next day I replaced the fluid and filter. Now it seems to not want to shift and sometimes you have to pop in in N then back to D for it to shift.
Is this a bad trans or could it be a bad PCM or TPS?
BuzzZJ9er is offline
post #2 of 8 Old 05-14-2013, 03:09 PM
tucsonzj
I let ratmonkey or someone else correct me, but could be linkage.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #3 of 8 Old 05-14-2013, 03:33 PM
dusterdude
Did you replace the additive that you drained out?
dusterdude is online now
post #4 of 8 Old 05-14-2013, 03:37 PM Thread Starter
BuzzZJ9er
I tried some but didn't do much. He wouldn't say what he actually did to it just said it was "an old Indian trick". He's not even Indian..? :brick wall:
post #5 of 8 Old 05-14-2013, 03:41 PM
tucsonzj
Yea, thats a bad sign.
tucsonzj is offline
post #6 of 8 Old 05-14-2013, 04:08 PM Thread Starter
BuzzZJ9er
Ya. I know he beat on it when he took it out so idk if he f****** it up and just ain't admitting it. it sucks seeing it just sit!!
post #7 of 8 Old 05-14-2013, 04:25 PM
PolkaPower
They don't have aux transmission coolers and they often overheat without them. This was a big mistake for 98 ZJ's.
You could try to find the gov pressure sensor and solenoid out of a JY ZJ and see if replacing those works but if you are not having a check engine light then it may not be the issue.
As a last resort I would try a couple bottles of some additive like maybe Lubeguard Red. Other than that you will probably need a re build but that will give the the chance to put a shift kit in and make it better.
PolkaPower is offline
post #8 of 8 Old 05-14-2013, 04:50 PM Thread Starter
BuzzZJ9er
A friend, who re builds his own ford trans, is supposed to help me re build it. If I didn't have to I wasn't going to though. What's a shift kit do for it?
