44RE. Transi Noise - JeepForum.com
post #1 of 4 Old 07-26-2011, 11:40 AM Thread Starter
4Tom
44RE. Transi Noise
I've a WJ 3.1 TD Diesel (sold in UK & Ire.) it has the 44RE I though I post here as I believe 44RE was fitted in the V8 ZJ.
metal fast clinking noise coming from transmission when the revs reach 1400 revs and goes away before revs reach 1500 in park neutral and in drive. (slightly lower rev when driving)
Thought it might be the exhaust hitting somewhere as it does sound very much like it's vibrating of off body part. Crawling under the jeep I inspected then poked and pried the exhaust but it doesn't seem to be hitting anywhere. But the sound seems to be loudest at transmission bell housing
where it bolts to the engine.
less noise at oil sump so I suspect flex-plate or torque converter bolts but I don't know.
Any suggestions greatly welcome.
WJ 2001 3.1TD
Tom
4Tom is offline
post #2 of 4 Old 07-26-2011, 12:40 PM
jreyes0a39oz
check the flexplate bolts to see if they are loose just remove the small plate check your fluid and motor mount
jreyes0a39oz is offline
post #3 of 4 Old 07-26-2011, 03:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I thought the diesel has the 545rfe?
ratmonkey is offline
post #4 of 4 Old 07-28-2011, 05:40 PM Thread Starter
4Tom
Yep that's what I thought too but I was informed it's a 44re by other 3.1 owners
I've not found the ID plate on tranny.
This is extract from build sheet
AWSS Smoker's Group
A65P 5.7L Eng(EZD)/5Spd A/T 545RFE (DGQ)
BAZS 136 Amp Alternator
BCVP 700 Amp Maintenance Free Battery
BRYS Anti-Lock 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CBWS Highline Door Trim Panel
CFNS Rear 60/40 Folding Seat
CGWS Next Generation Front Air Bags**
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKRP Cargo Net
CKTS Cargo Tie Down Loops
CLEP Front & Rear Floor Mats
CLGS Covered Cargo Storage
CLPS Door Sill Scuff Pads
CSCP Cargo Compartment Cover
CSRS Passenger Assist Handles
CUDS Mini Overhead Console
CUFS Full Length Floor Console
DGBS All 4-Speed Automatic Transmissions
DGW 4-Spd. Automatic 4RE Transmission
DHAS Lock-Up Torque Converter
DHFS Quadra-Trac II On Demand 4WD System
DJJS Dana 30/186MM Front Axle
DMTP 3.90 Rear Axle Ratio
DRKS Dana 44/226MM Rear Axle
EAAC All Engines
EXA 3.1L I5 Turbo Diesel Engine
WJ 2001 3.1TD
Tom
4Tom is offline
