42RE transmission speed sensor replacement - JeepForum.com
post #1 of 4 Old 01-21-2009, 05:18 PM Thread Starter
jetdude
Hi, I have a 96GC with a 42RE tranny and want to replace the transmission output speed sensor. the one in there apparently has a failing seal and is leaking slightly. I got a new one at the dealer and it looks like it threads in. my question is is this an easy part swap and how much fluid can I expect to come out after I remove the old sensor? thanks
jetdude is offline
post #2 of 4 Old 01-21-2009, 05:43 PM
cmonson
this is a 2 min fix. Take the elec connection off, have the new sensor ready, screw out the old, and quickly install the new, put elec connection back on. You will lose VERY little fluid...
cmonson is offline
post #3 of 4 Old 01-21-2009, 06:29 PM Thread Starter
jetdude
thanks for the info
jetdude is offline
post #4 of 4 Old 01-21-2009, 08:11 PM Thread Starter
jetdude
It was the end of the mystery. the trans seemed to be shifting a little delayed for a few days. when I went to remove the electrical connector from the speed sensor the wires were torn out of it all fixed now and shifts like new again and no leak.
jetdude is offline
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 05:47 PM
42RE Transmission Temp Sensor CP-Mike ZJ Grand Cherokee Forum 11 10-06-2010 05:13 PM
Speed sensor replacement on 94ZJ 4.0 CrazyDrivinJoe ZJ Grand Cherokee Forum 3 10-19-2009 04:59 PM
Is there a writeup for complete transmission fluid replacement? 42re? 01grander ZJ Grand Cherokee Forum 2 12-10-2006 02:23 PM
Transmission / Speed Sensor Help! pdmoyes ZJ Grand Cherokee Forum 2 05-13-2005 08:14 AM
