42RE tranny questions - Page 2 - JeepForum.com
post #16 of 21 Old 12-04-2009, 02:22 PM
Tooms1121
2012 WK
just my 2 cents...these transmissions are like grenades, you just wait for them to blow up. had mine rebuilt @ 130k and now i religiously change the fluid every 30k. when they start to hiccup its usually a long slippery slope, time to save up for a rebuild.
Tooms1121 is offline
post #17 of 21 Old 01-25-2014, 12:57 PM
76Pacer
Which trans fits an AMC 4.0L/4.2L? A500? 42RH? 46RH?
Hi All: I am going crazy with this title's question. I need to find a non electronic 4 spd OD trans which will bolt to my 4.2L 6 cyl AMC engine. The CHRYSLER {not AMC} transmission class of A500/42RH and perhaps the 46RH has different bellhousing {starter is on the wrong side for AMC}, hence I must find one that was used only in Jeep. However, I can't find out which Jeeps used the A500/42RH. I don't want a 42RE. I'm beginning to think that A500/42RH were NOT used in Jeep and only the Aisan AW4 and 42RE were. But I noticed that there was a 46RH was used in some Jeeps. Questions: 1. WAS the A500/42RH ever used in any Jeep? 2. If not, then was the 46RH used in Jeep? 3. If so, is the 46RH similar to the 42RH and I can then manually operate the OD and 4th gear with toggle switches? 4. Would the 46RH fit my AMC 4.2L six? Please help. I got to get this project going and done so I can do the Woodward Dream Cruz this year. THANKS! This stuff takes lots of time {and $$$}.
76Pacer is offline
post #18 of 21 Old 01-25-2014, 04:21 PM
shaban
There was no 42RH, XJ's had either AW4 or 30RH (3-speed). ZJ's used either AW4 or 42RE. 46RH was only used on pre-96 v-8 motors, and it's got a different bellhousing pattern to AMC 4.0
So:
1. No 42RH wasnt used on any jeeps as far as I know; 30RH could be your choce but I'd rather go with AX15 manual.
2. It was used on pre-96 ZJ's with 5.2 v8 engines, different bellhousing bolt pattern
3. Yes it's similar, you just need to control the 4th gear and TCC via 2 solenoids.
4. No unless you can fab an adaptor plate
shaban is offline
post #19 of 21 Old 01-25-2014, 04:30 PM
dusterdude
Hughes performance(i think) sells removable bellhousings that will bolt to your engine and bolt to your particular tranny.google them and see if im correct
dusterdude is offline
post #20 of 21 Old 01-25-2014, 04:54 PM
jeepyard
Originally Posted by keenphis View Post
Anybody? Or is this just me being a dumb@$$?
I had my transmission built on my 98 4.0 with the 42RE and the guy that built it said to remove the factory check valve in the transmission cooler line. He said he would not warranty the tranny if I did not do this. I pulled it and put it back in myself and this check valve is made as a rubber hose assembley at the front of the engine close to the oil pan. He said if the check valve stick it will starve the transmission of fluid and it will die!! I did have a problem last year with it jumping in and out of overdrive at highway speeds that wound up being a bad TPS (throttle position sensor) that had a glitch in it and was tricking the tranny into thinking it was at WOT instead of just a steady cruising speed. Replaced the TPS and it fixed it and that was back in late 2012. Just some suggestions!!
jeepyard is offline
post #21 of 21 Old 01-25-2014, 05:01 PM
jeepyard
Originally Posted by 97JGC2WD_AA View Post
I am not sure what I did incorrectly to elicit the above response but I am new to this forum and am not sure
of all the proper procedures. I did read somewhere about searching first for answers and not starting repetitive
threads. That's the reason I tagged onto this one. If I have used the wrong protocol perhaps someone could send a private message to help me understand the correct procedure to follow to ask a question.
I am sincerely looking for an answer for my 1997 Grand Cherokee 4.0 / 2WD transmission problem.
My Jeep is not driveable as it is.
Thanks for any assistance.
Its bad for me to jump to this conclusion but its sounds like the check valve in the cooler line stuck and starved the tranny of fluid. It will most likely need a rebuild and make sure whoever does it gets rid of that check valve or it will happen again. I have four of these jeep in my family and I have done away with the check valves on all of mine since the guy at the transmission shop told me to get rid of them!!!!
jeepyard is offline
42RE tranny questions and codes!! cracked ZJ Grand Cherokee Forum 0 12-30-2009 12:11 AM
Tranny, Filter, and service questions? 42RE GUYS IN HERE Dopalmer ZJ Grand Cherokee Forum 5 05-13-2009 04:13 PM
42RE Tranny ledfoot02 ZJ Grand Cherokee Forum 6 09-23-2008 07:43 AM
42RE tranny issue 4Slow9erHybrid ZJ Grand Cherokee Forum 8 05-29-2008 03:31 PM
42re tranny changes??? woodmanxxx ZJ Grand Cherokee Forum 0 09-09-2005 10:01 AM
