42RE overdrive problem 98 GC 4.0L - JeepForum.com
post #1 of 7 Old 09-14-2006, 09:54 AM Thread Starter
stufor
New subscriber that has registered looking for help with this specific situation. I have a 98 GC Laredo. The transmission flutters in & out of overdrive momentarily & occasionally at any speed that overdrive is engaged. Trans shop says there is nothing wrong with the transmission that can be detected thru diagnostics. Fluid & filter change bands adjusted etc. with no affect. The general opinion is an electrical momentary interruption caused by some connection, sensor, switch or something. Happens with or without cruise control activated. The transmission functions flawlessly in all other situations hot or cold.
Anyone out there had a similar problem? Looking for suggestions.
stufor is offline
post #2 of 7 Old 09-14-2006, 10:14 AM
etoracca
If trans diagnostics are ok (both fault codes and pressure), did you check the O/D switch ?
bye
Enrico
WJ 4.7 V8 MY02, LPG, K&N filter, Daystar 2" lift, Skyjacker shocks, Xlerator Perf, Akebono calipers, Power Slot rotors
etoracca is offline
post #3 of 7 Old 09-14-2006, 11:42 AM
GCJeeper1993
I have been having basically the same problem with my 93 5.2 Limited. I still have not gotten an answer on the problem yet. My thread is under the heading of "Transmission expert needed." I am watching any threads hoping to find the answer to the problem. Good luck and let me know if someone answers your thread with the correct diagnosis and I will do the same.
Karl
New Jeep Guy
1993 Grand Cherokee Limited
5.2L White with gold trim
242 XJ conversion
GCJeeper1993 is offline
post #4 of 7 Old 09-14-2006, 12:57 PM
CajunWon
If you're speaking of a 1-200rpm fluctuation: This is common. Mine went away when I flushed the ATF & changed to ATF+4 (now a DCX requirement). But if you just changed the ATF+4 (with ATF+4), then I wouldn't worry about it.
If your issue is it goes from 2k to 2.6k or 3k rpm, then your kick-down cable needs adjusting.
imo
CajunWon is offline
post #5 of 7 Old 09-14-2006, 02:50 PM Thread Starter
stufor
Enrico
bye
Enrico
I appreciate your reply. I have not checked the switch other than to say if you use it, it does what it is supposed to do. What would you suggest as proper testing?
stufor is offline
post #6 of 7 Old 09-14-2006, 02:56 PM Thread Starter
stufor
Cajunwon
imo
It is a slight fluctuation 1-200 range. I use Mobile 1 full syn atf. Not familiar with +4. What is it. I have had jeeps since 1979 to include a 1996 GC with same set up and also currently also own a 1999 gc laredo with same set up. I have never had any other one do this. I am a little anal and really believe that something is not quite right.
stufor is offline
post #7 of 7 Old 09-14-2006, 03:11 PM
CajunWon
OK: that's not Overdrive related -it is the Lockup Torque Converter. And has everything to do with the ATF you are using.
Chrysler says to use ATF+4 on all their TorqueFlight Transmissions. I understand this ATF type has recently become available in regular parts stores for ~$4/qt. You will need at least 10qts to flush-out the Mobil. Search for "DIY Transmission Flush" procedures. **oh wait, we can't search now** anyway it's not much harder than a simple ATF change.
I'm no mechanic -YMMV
CajunWon is offline
1996 ZJ 42re Lost Overdrive 242forme ZJ Grand Cherokee Forum 13 01-11-2010 05:48 PM
42RE transmission overdrive unit drespecki ZJ Grand Cherokee Forum 0 11-29-2009 12:06 AM
overdrive problem in my 93 zj ManikJeepZJ ZJ Grand Cherokee Forum 8 12-18-2008 11:15 PM
Overdrive problem _H2_ ZJ Grand Cherokee Forum 2 01-19-2008 07:25 AM
42RE lost overdrive :S jeepunlimited ZJ Grand Cherokee Forum 2 05-24-2007 06:09 PM
