42RE no od or tc lockup. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 42RE no od or tc lockup.
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 10-11-2009, 09:42 PM   #1
bird59
93 1/2 with 159K, fluid and filter changed, no tcm or pcm codes. Adjusted bands to factory specs, Checked resistance and cleaned the od and tcc solenoids. Checked temp thermistor, all checked good. Is this turning into a valve body problem? I'm starting to think a boneyard replacement may be in order.
bird59 is offline   Reply With Quote Quick reply to this message
