42re Band adjustment alternative... - JeepForum.com
post #1 of 7 Old 03-12-2013, 11:04 AM Thread Starter
congerz83
I know this question will horrify the purists, but instead of spending $ on a torque wrench in inch/lbs, why not loosen the lock-nut and just move in the direction you need? Maybe 1/2 turn at a time?
My other question is, if you have a sluggish 1-2 shift and you believe it to be the band, do you loosen, or tighten the front band?
THIS IS WHY I HATE AUTOMATICS
congerz83 is offline
post #2 of 7 Old 03-12-2013, 12:51 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The torque wrench is required. Its the only way to set the zero point for the application of the bands.
ratmonkey is offline
post #3 of 7 Old 03-12-2013, 01:22 PM
OverlandZJ
congers, you can score a cheap 0-60 in/lb torque wrench on ebay for $40 shipped. I just bought a Park TW-1 the other day.
Rat.. will a 0-60 range TW work on adjusting bands?
OverlandZJ is offline
post #4 of 7 Old 03-12-2013, 01:32 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
72inlb is the spec.
post #5 of 7 Old 03-12-2013, 02:33 PM
LouC
2007 WK
If you are working on your own stuff a torque wrench will SAVE you money in jobs done right the first time and not breaking things.
THIS IS WHY I HATE TIRE SHOPS AND IMPACT GUNS....
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #6 of 7 Old 03-12-2013, 03:45 PM
OverlandZJ
Originally Posted by ratmonkey View Post
72inlb is the spec.
Yeah, that figures. Guess thats another tool i should pick up..
post #7 of 7 Old 03-12-2013, 07:05 PM
4Slow9erHybrid
an inch-lbs torque wrench for ~ $60 or a transmission rebuild for ~$2000? Tough choice.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
