42re to 46rh swap - JeepForum.com
post #1 of 13 Old 03-26-2009, 07:15 PM Thread Starter
jhotrod83
42re to 46rh swap
I have an extra 4rh trans that i would like to put in my wifes GC. Her 42re trans is a piece of junk. I don't want to pull it apart to find out that it doesn't bolt up or wont shift. Will the torque converters bolt up or can I reuse the 42re converter? Both trans are out of 93 GC's. The wifes has a 4.0 and the donor trans was behind a 5.2. Any info would be appreciated
95 Limited 5.2, 7in lift 8 adj control arms, 36x13.5 iroks, custom 3in y pipe, high flow magnaflow cat flowmaster 40, KOR radiator suport, and plenty of trimming
jhotrod83 is offline
post #2 of 13 Old 03-26-2009, 07:16 PM
baxy
well an RH is way longer than an RE so are you sure which transmissions you have
baxy is offline
post #3 of 13 Old 03-26-2009, 07:30 PM
gman1322
gman1322's Avatar
Bellhousings will be different between V8 and 4.0L.
gman
2008 Jeep Liberty Sport
- 3.5" Rock Krawler, 245 75 16E Treadwright Warden AT's, Jet Stage One Chip
2007 Dodge Ram 1500 4WD
- Superchips 3865, 305 55 20 Nitto Grappler MT's, Hellwig sway bar, Powerwire, Sonnax Line Pressure booster, Bilstein Leveling Kit and rear shocks
gman1322 is offline
post #4 of 13 Old 03-26-2009, 07:33 PM
baxy
LOL I missed that part of the thread good call
the jig is up
rebuild the 42RE add a few parts from a 44RE and upgrade it
baxy is offline
post #5 of 13 Old 03-26-2009, 07:34 PM Thread Starter
jhotrod83
im sure about what trans I have. The only issue with a longer trans is driveshaft length and Im not worried about that. I just didn't know if it would bolt up
post #6 of 13 Old 03-26-2009, 07:35 PM Thread Starter
jhotrod83
thanks for the info guys. Guess a rebuild is in my near future
post #7 of 13 Old 03-26-2009, 07:37 PM
baxy
make it into a 44 and add a shift correction package and it will handle almost anything you can throw at it within reason
baxy is offline
post #8 of 13 Old 03-27-2009, 06:57 AM
Marcos
Anyone know off the top of their head what internal parts are upgraded from a 42 to a 44?
Marcos is online now
post #9 of 13 Old 03-27-2009, 07:16 AM
gman1322
gman1322's Avatar
Been since 2002 since I left the business so bear with me.
I would say check the planetaries for more pinion gears, overdrive clutch capacity for more clutches. You can order the pressure plates and clutches to build it up to the 618 series, but that may be overkill for a 4.0L. It's all in what you want to spend. Definelty check the radiator cooler for proper flow and add an external cooler after the out line of the radiator cooler.
If you do the shift kit, make sure to follow the instructions in detail. Get those bands adjusted properly.
Do you have an ATSG manual to refer too? It will help.
gman
gman1322 is offline
post #10 of 13 Old 06-22-2014, 11:15 AM
08bsplifesvr
Sorry to revamp a dead thread but can't he swap out the overdrive unit at the end of the transmission and the driveshaft (as long as the rear diff matches?
08bsplifesvr is offline
post #11 of 13 Old 06-22-2014, 01:38 PM
PolkaPower
One is hydraulic and the other is electric.
PolkaPower is offline
post #12 of 13 Old 06-23-2014, 04:31 PM
08bsplifesvr
Shouldn't the hydro tranny work in place of the electric but not the other way around?
post #13 of 13 Old 06-23-2014, 04:41 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes but the PCM won't like it.
kg6mov is offline
46RH swap BlackDaddyZJ ZJ Grand Cherokee Forum 3 01-28-2010 08:31 AM
Will a 98 42RE swap into a 94 4.0L =KZ= ZJ Grand Cherokee Forum 10 11-29-2009 08:40 AM
42RE to AX-15 swap FAQ parvizus ZJ Grand Cherokee Forum 3 07-26-2007 08:08 AM
46RH compatibility - swap for ? RT8827 ZJ Grand Cherokee Forum 9 09-12-2006 09:26 PM
97 42re swap ?????????? airmech691 ZJ Grand Cherokee Forum 1 12-05-2004 11:10 AM
