42re to 44re swap - JeepForum.com
post #1 of 7 Old 10-29-2007, 10:47 AM Thread Starter
angry troll
42re to 44re swap
my 94 grand has 207### miles and the 42 is starting to slip. i have an opertunity to get a 44re for real cheap and would like to know if it is do-able. if i could get some info that would be great. thanx, T
i forgot to mention i have an I-6 and was not told what engine was in the other. i do know it was in a 4x4. in that brings up another question.... will the transfercase match? again thanx.
angry troll is offline
post #2 of 7 Old 10-29-2007, 11:40 AM
ZJMAN
To the best of my knowledge they never put a 44Re behind the 4.0. So you'll have to swap the guts of the 44 into the 42 case. This is a frequent swap and will give you HD components.
ZJMAN is offline
post #3 of 7 Old 10-29-2007, 12:19 PM Thread Starter
angry troll
ok so just use the guts from the 44 and new steels and frictions? what kinda improvement will this be? just trying to figure it out. so is it the bell housing, length, anyting obvious? just trying to do a quick swap to get the jeep going till i get a rebuild kit for the 42. thanx for the info on the HD conversion.
post #4 of 7 Old 10-29-2007, 12:21 PM
CLNinja
CLNinja's Avatar
try to get an AW4
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #5 of 7 Old 10-29-2007, 11:57 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
With a 94, I would also try to get an AW4. But to answer your question, the 44RE was used behind the V8 in 96-98. So I do not think that the tranny will work. But I have heard of swapping the internals of the 44 into the 42 but I do not any specifics.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #6 of 7 Old 10-30-2007, 01:59 PM
ZJMAN
I do know that there are more clutch disks and other internals are heavier on the 44. I'll try to check my shop maual tonight for specifics.
ZJMAN is offline
post #7 of 7 Old 10-30-2007, 09:40 PM
ZJMAN
My shop manual says that the differences are in fact the clutch packs.
Front Clutch:
42RE - 4 discs
44RE - 5 discs
Rear Clutch:
Both trans use 4 discs
Overdrive Clutch disc Usage:
42RE - 3 discs
44RE - 4 discs
Direct Clutch disc usage:
42RE - 6 discs
44RE - 8 discs
All other specs appear to be the same.
ZJMAN is offline
5.2 44re swap 2 46re 97zjjeep ZJ Grand Cherokee Forum 0 12-27-2009 08:10 AM
42RE Upgrade to 44RE? ZJJay ZJ Grand Cherokee Forum 1 12-25-2009 08:06 PM
Can I swap a 44RE with a 42RE ? weberdm1980 ZJ Grand Cherokee Forum 2 11-18-2009 09:58 PM
44RE in place of 42RE?? HomeSpun ZJ Grand Cherokee Forum 3 03-10-2008 04:07 PM
42re-->44re???? legend6009 ZJ Grand Cherokee Forum 4 04-19-2007 02:42 PM
