4.Slow engine swap question - JeepForum.com
post #1 of 1 Old 05-24-2010, 02:39 PM Thread Starter
Crippler
So i recently swapped 1994 4L into a 1996 zj. i reused as many of the 1996 bolt on parts as possible without much problem. However, i have had some issues with serpentine belt.
So here is is my question, i used the 96 intake and power steering pump/belt tensioner. So should the only other change i need to use the 96 belt on the 94 engine is to remove the lower idler pulley from the 94 setup?
1996 ZJ 7.5" of lift/Rusty's Long Arms/36" TSL's on 15X10 Granite Alloy's/Trussed D30HP/Trussed D44Hd /Berserk Icelandic Offroad Fender Flares/Custom rear bumper and tire carrier/4.56 gears
2005 Dodge Magnum RT
Crippler is offline
4.0 engine swap question? TravisP32 ZJ Grand Cherokee Forum 4 09-11-2009 09:32 PM
Question About a 4.0 engine swap tdd8ball ZJ Grand Cherokee Forum 4 09-03-2009 12:23 PM
Engine swap question Fiend101 ZJ Grand Cherokee Forum 2 03-15-2009 09:06 PM
Engine swap question joemadoo ZJ Grand Cherokee Forum 11 05-22-2008 06:35 AM
Engine swap possibilities to take place of 4.slow slick2570 ZJ Grand Cherokee Forum 12 09-03-2007 02:01 PM
