4" lift + 1" spacer - JeepForum.com
post #1 of 6 Old 07-14-2007, 08:07 PM Thread Starter
eXtremeJeep
4" lift + 1" spacer
I just bought a 4 lift today for my 94 ZJ. This is the list of components its said to come with:
Front and rear coil springs
Front and rear adjustable lower control arms
Rear adjustable upper control arms
Front and rear track bar drop brackets
Front extended length sway bar links
Rear sway bar brackets
4 Rough Country 8000 Hydro Shocks
All necessary hardware
Installation instructions
One thing I noticed missing from the kit was a T-Case drop. The guy on the phone said I dont need one but I think with 5 (see below) of lift I most definitely will.
I am also planning on adding a set of 1 polyurethane spacers. Do I need to also replace my bump stops for this (or buy bump stop spacers)? I have tried searching and reading but cannot find any definitive answer.
eXtremeJeep is offline
post #2 of 6 Old 07-14-2007, 08:09 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You can mess around without the tcase drop and see if you have vibes before you add it. Now, teh bumpstops should be as least as long as your new lift.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 6 Old 07-15-2007, 08:41 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
You prolly won't need the t-case lowering kit.
I don't like trackbar relocation. Adjustable track bars are really the way to go.
2013 FR-S
BlaineWasHere is offline
post #4 of 6 Old 07-15-2007, 10:01 AM
FPKites
ZJjazzyJim
FPKites's Avatar
You want to avoid TC drops unless you really need them. You'll probably be okay. Melt down that trackbar relocation bracket and make a nice piece of bling out of it
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 6 Old 07-16-2007, 11:03 AM
FortCollinsZJ
Yes the drop down brackets are crap, they will break and crack even on a street queen! JKS makes the best trackbars in my opinion..brackets ad extra force to the pre existing mount = cracked off old mount. If it breaks off completely while driving.. you are probably going to be out of control and off the road.. in a hurry. As for bumpstop extentions.. I am on a 4.5 lift and i have stock bumpstops. They really only need to be longer if you put on much bigger tires (an inch or 2 wont do to much) i am just going to put some hockey pucks in the front springs and that will solve that. and I dont believe you will need to drop your transfer case... just wait and see after you have the lift installed.
FortCollinsZJ is offline
post #6 of 6 Old 07-16-2007, 11:08 AM
ajmorell
ajmorell's Avatar
If you can get your hands on adj trackbars do it and sell the brackets to someone who doesn't know different. Depending on how much you are going to wheel you may also want to invest in some front swaybar disconnects as well. As for the t-case drop, with adjustable upper arms for the rear, you probably won't need it. I needed one at 4.5" but I am still running stock upper arms (for now....)
ajmorell is offline
2" spacer lift guitarZERO ZJ Grand Cherokee Forum 20 06-03-2009 06:07 AM
Question reg. 2"-3" spacer lift the squirrel ZJ Grand Cherokee Forum 7 05-09-2009 01:14 AM
2"-2.5" Coil Spacer lift Jammer73 ZJ Grand Cherokee Forum 2 11-02-2008 08:56 PM
2" Spacer lift with 265/70 R17 - Go or no Go? Polaris Junkie ZJ Grand Cherokee Forum 15 08-30-2006 09:36 AM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 11:17 AM
