4" IRO LA Complete kit? - JeepForum.com
post #1 of 22 Old 07-08-2009, 08:01 PM Thread Starter
jdharri7
Hey, I am looking at getting the IRO 4" critical path front long arm kit for my WJ. And I'm just wondering if there is anything else that I should include to give my Jeep the perfect ride on and off road as it is my DD.
Kit Includes:
Set of 4 new coil springs (4" Lift)
Set of 4 new premium hydro shocks with boots
Set of 4 new extended sway bar links (2 front, 2 rear)
Heavy duty track bar
A-arm spacer
Complete front long arm package (passenger long arm and driver Iron-Y)
Heavy duty front long arm brackets
Transfer case drop kit
Coil spring retainers
Front brake line spacers
Caster adjuster bracket
All necessary hardware
I will definatly upgrade to Doetsch Tech 8000 Shocks, the JKS quick discos, and the adjustable track bar. Would I need anything else? Such as bump stops? What if anything am I missing? Thanks guys!
02 Grand Cherokee, 4.7L V8, 2" BB, K&N Intake, Shaved Door Handles. Selling stock Tail Lights, Headlights, and Door Handles!
jdharri7 is offline
post #2 of 22 Old 07-08-2009, 08:08 PM
Jones
Consider the following...
Jones's Avatar
You won't have the perfect ride unless you get front and rear long arms. The front of that kit will ride great, the rear will be rough.
Jones is offline
post #3 of 22 Old 07-08-2009, 08:21 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Actually the WJ rear suspension is better than the ZJ. It won't be bad because you will get an a-arm spacer but if you want it to better go with adj. control arms or rear long arms. But the WJ rear suspension flexes really well though.
Bumpstops depend on what size tire you run. The best way to do measure for them is get the lift installed, get the tires you want and flex out your suspension to the max. Measure what length you will need.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 22 Old 07-08-2009, 08:22 PM
the88thpianoman
2003 WJ
Depends on how much coin you want to drop, but if you're really looking for "the perfect ride on and off the road" then subtract the shocks from that kit altogether and source some Bilsteins or another quality monotube.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 22 Old 07-08-2009, 08:24 PM
xJoshxx
2012 WK
x2
And get a Trail Boss SS MOOG
Do you really need brake line Spacers at 4inchs?
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 22 Old 07-08-2009, 08:25 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by xJoshxx View Post
x2
With long arms, better safe then sorry.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #7 of 22 Old 07-08-2009, 08:27 PM
xJoshxx
2012 WK
good cause im t-rexing it lol yea long arms more up down movement.
glad im just a street queen that likes bad weather lol.
2011 WK2 ORA2 sold
xJoshxx is offline
post #8 of 22 Old 07-08-2009, 08:40 PM Thread Starter
jdharri7
Thanks for all the fast responses!
I would love long arms but can't afford them now. Hopefully I will get the Clayton long arm upgrade sometime soon after though!!
So with the bump stops, how do I know what length to get? Im goin to be running 265/70R17s for now with is about a 31.6in tire.
jdharri7 is offline
post #9 of 22 Old 07-08-2009, 08:43 PM
gatorayde
I'd say 4" bumpstops would be enough, then trim whatever rubs. I'd let someone chime in that's run that exact setup though before making your decision.
And no, rear long arms aren't needed until ~6". The ride will be fine at 4" because when going over bumps the control arms will want to rotate backwards, whereas with front arms, they want to rotate forward and upward causing a harsh bump. Even at 4" and crappy shocks, the ride is tolerable with front short arms.
gatorayde is offline
post #10 of 22 Old 07-08-2009, 09:11 PM
tsconver
2003 WJ
measure the hub to fender now and then after the lift and add the difference to the bumpstop length.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #11 of 22 Old 07-08-2009, 10:24 PM Thread Starter
jdharri7
With a 4" lift, do I even need bumpstops? And honestly I'm not even exactly sure on what they do, just make sure there is not metal on metal rubbing?
jdharri7 is offline
post #12 of 22 Old 07-08-2009, 10:29 PM
GraKee99
Rapist Wit
GraKee99's Avatar
The prevent the tire from getting into the fender or other unwanted areas. What size tires do you plan on running?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #13 of 22 Old 07-08-2009, 10:38 PM Thread Starter
jdharri7
31.6s. Which I'm almost positive will not rub even at full flex. Am I wrong?
jdharri7 is offline
post #14 of 22 Old 07-08-2009, 11:02 PM
GraKee99
Rapist Wit
GraKee99's Avatar
No you should be good. So I am guess 265/75/16 then? But like I said before the best thing is get everything installed and test it. Max out the flex and if you need bumpstops then, measure and order them. You don't want to be on the trail and a tire eat into your fender, it isn't fun.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #15 of 22 Old 07-08-2009, 11:08 PM Thread Starter
jdharri7
Well its 265/70R17 but yeah. So I dont understand how bump stops will stop the wheel from going into the fender. Does it just lengthen the lift so that the wheel can't reach the fender?
jdharri7 is offline
5.9 project is complete Elkaholic ZJ Grand Cherokee Forum 72 01-07-2009 09:42 AM
Complete Nooby here, i want a 4" or higher lift, what all do i need to do? CatDang ZJ Grand Cherokee Forum 31 07-24-2008 07:55 PM
Complete Offroad ickydoo ZJ Grand Cherokee Forum 6 01-16-2008 02:39 PM
WJ Complete BucYouUp68 ZJ Grand Cherokee Forum 4 10-23-2007 01:32 AM
Project "Get a ZJ" phase 1 complete ZJenvy ZJ Grand Cherokee Forum 4 06-02-2005 12:27 PM
