4 inch springs on a 3 inch lift?? - JeepForum.com
post #1 of 9 Old 04-21-2005, 08:52 PM Thread Starter
zj333
haha im sorry if this is a dumb question but im just at a loss to what this actually does i mean i have an idea...it lifts the truck more but what about the control arms and other things what happens to them with the bigger springs?/
thanks guys
zj333 is offline
post #2 of 9 Old 04-21-2005, 09:04 PM
got4-Lo
shocks should the only thing that u need
stretched *** tj
got4-Lo is offline
post #3 of 9 Old 04-21-2005, 10:08 PM Thread Starter
zj333
ohh ok sweet so you can use all the control arms and components on the 3 inch lift but just upgrade it to a 4 inch with shocks and springs
zj333 is offline
post #4 of 9 Old 04-21-2005, 11:20 PM
Colorado 5.9
Colorado 5.9's Avatar
Most 3" lifts only come with lower adjustable control arms. If so, you really need upper adjustable control arms to adjust the pinion angles to where they should be at 4" or higher. There are some guys that have gotton away with stock uppers & 4" to 5" but it will sooner or later trash the pinion bearings if you can't get the angles right. Allso you'd most likely end up with bad vibes.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #5 of 9 Old 04-22-2005, 06:34 AM
jeepholic
jeepholic's Avatar
This is not true at all.
You need lots of other stuff to lift 3"+
Track bar relocation
SS
extnded end links
maybe even longer brake lines
WE have hundreds of threads on the subject, take some time and search.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #6 of 9 Old 04-22-2005, 08:19 AM
got4-Lo
SS
extnded end links
what i meant was the u will need longer shocks, the oem are too short, of over compress the shock it will get damaged. which means leaks blah blah. u are better off getting a whole kit, then tryin to piece one together. depending on what tire ur tryin to clear an RE 4.5 super flex will clear 33's with minimal trimming and hammering
stretched *** tj
got4-Lo is offline
post #7 of 9 Old 04-22-2005, 08:30 AM
jeepholic
jeepholic's Avatar
NOW that's some great advice!!
I pieced one together and am very sorry.
I use a Jeep
You drive a car
Big difference.
post #8 of 9 Old 12-20-2009, 05:48 PM
urq2
urq2 is offline
post #9 of 9 Old 12-20-2009, 06:02 PM
Technohead
WOW, talk about bringing a thread back from the dead . . .
Looks good though!
-Eric
Technohead is offline
Torn between 4 inch and 4.5 inch lift for my ZJ givemeazj ZJ Grand Cherokee Forum 21 08-07-2011 10:42 PM
3 inch lift.. 1 inch bb? coopdc78 ZJ Grand Cherokee Forum 8 11-09-2009 08:03 PM
2 Inch lift vs. 2 Inch Spacers jeep_05 WK Grand Cherokee & XK Commander Forum 19 06-06-2008 02:57 PM
3 inch lift JerseyStepUp ZJ Grand Cherokee Forum 23 04-08-2008 07:39 AM
UC Spring VS. 1 inch lift springs TheCompound ZJ Grand Cherokee Forum 7 05-09-2006 11:21 PM
