4.7L V8 Towing capacities - JeepForum.com
post #1 of 11 Old 02-06-2010, 11:05 AM Thread Starter
Nick
2006 WK
I was surprised I couldn't find any answered threads through search, but does anyone know the towing capacity of the 4.7L V8 WJ?
I've been looking into buying a WJ to tow my XJ, and to use as a DD. Which years are best? I know next to nothing about the Grand Cherokee.
Thanks for your help!
2001 WJ | 4.7L V8 |
Hemi Club Member 60
1990 White XJ Laredo [Sold]
2000 Silverstone XJ Classic [Sold]
2006 Dodge Charger RT Hemi [Sold]
2001 Jeep Grand Cherokee [Current]
Xbox Live gamertag: XJ Nickk
Originally Posted by DcMuff View Post
Banned for being the cooler Nick
Nick is offline
post #2 of 11 Old 02-06-2010, 11:21 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its 6,500 lbs according to Jeep.
It will flat tow your XJ decently, but if you want to trailer it, you'll be pushing it.
Wheelin98TJ is offline
post #3 of 11 Old 02-06-2010, 11:26 AM Thread Starter
Nick
2006 WK
6,500 without any kind of towing package?
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
post #4 of 11 Old 02-06-2010, 11:43 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
No its 6,500 with class 4 towing package w/ trans cooler, PS cooler, 3.73 axle ratio, etc.
The 6,500 pounds also included the cargo in your Jeep, your personal weight, etc.
http://www.wjjeeps.com/trailer.htm
The combined weight of the trailer is 10,500, my door jam says my jeep weighs 5,500, so I guess i can only tow 5,000??
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 11 Old 02-06-2010, 11:46 AM Thread Starter
Nick
2006 WK
I see, thanks for your help, I' m going to read over that website you listed.
Thanks again!
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
post #6 of 11 Old 02-06-2010, 11:50 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
You'll know enough to purchase a WJ after reading that site!
post #7 of 11 Old 02-06-2010, 11:54 AM Thread Starter
Nick
2006 WK
a WJ has been tempting me for quite awhile, in my area I can pick up a 2000-2003 for almost as much as I paid for my XJ, around 5K. I'd rather trailer tow my XJ, though, so maybe a WJ isn't for me.
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
post #8 of 11 Old 02-06-2010, 12:01 PM
horatio102
Your XJ weighs what, about 3500 pounds? With a 1000 pound aluminum flatbed, no problem. With a 2000 pound steel/wood trailer, it's doable, but consider spending the coin for a load leveling hitch and/or airbags for the back end.
I was able to put a 1978 Ford F150 4x4 on a flatbed and tow it ~30 miles home, but I was almost riding on my bumpstops in the back. Then again, I'm set up for wheeling, not towing heavy loads.
There's no shortage of power, with stock tires you'll be fine. I've got 33" tires and it makes a bigger difference than you'd think.
I'd get the smallest/lightest trailer you can afford that will handle your XJ, and then get a load leveling hitch and make sure you've got the factory HD towing package, and toss an electric brake controller in there. I think it was 2003 that was pre-wired for the brake controller. Oddly enough, I think it was only 2003.
horatio102 is offline
post #9 of 11 Old 02-06-2010, 12:19 PM Thread Starter
Nick
2006 WK
You're right, my XJ will likely weigh a little closer to 4,000 pounds after you factor in beefy bumpers and other accessories, but I think you've got a point. I'd keep this WJ stock, and it would just be a DD and would likely never see dirt.
I don't know that I'd be able to find a WJ with the factory HD towing package, but I could likely get all of the components from a stealership?
I've always liked the way the Grand Cherokee handles on the road, so if I can work it out that the WJ can handle the towing, I'll likely go with that over a Dodge Ram or something like that.
So, if it comes down to it, I'd want to get the 03' for the brake controller?
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
post #10 of 11 Old 02-06-2010, 12:23 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Adding a trans and PS cooler is easy. You can get universal coolers at NAPA
Also adding a hitch and the required wiring harness is easy. Try junkyards and forums for a used hitch. The harness plugs right in, behind the L side quarter panel.
You can also add a brake controller, so I wouldnt narrow down your search to 2003 just for that.
post #11 of 11 Old 02-06-2010, 12:29 PM Thread Starter
Nick
2006 WK
Gotcha. My father is a Jeep technician for a dealership here in Utah, so luckily I always have his expertise to fall back on.
So, this really does sound doable. I'd rather not buy a new trailer, but like Grand Cherokees, there are quite a few on the market most of the time. I haven't really done any heavy duty towing, just stuff under probably 700lbs, will a dual axle trailer be needed to handle the weight of the XJ?
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
Towing Package or Towing Prep Package? lma1973 ZJ Grand Cherokee Forum 26 03-07-2012 08:38 PM
Capacities and other questions about diff. and t-case fluid changes?(hemi qd II) 05hemiyc WK Grand Cherokee & XK Commander Forum 2 05-07-2009 05:36 PM
Front and Rear diff capacities? DarrylFlynn WK Grand Cherokee & XK Commander Forum 7 02-19-2009 12:22 AM
Towing wvresq ZJ Grand Cherokee Forum 14 05-24-2005 08:57 AM
1994 ZJ Fluid Capacities/Specifications Williamson_DC ZJ Grand Cherokee Forum 1 05-15-2003 12:05 PM
