4.7l V8 Pcm (powertrain Control Module) Failure - JeepForum.com
post #1 of 1 Old 07-02-2004, 10:21 AM Thread Starter
HUSKERJEEP
I HAVE A 2001 JGC WITH 75K. ENGINE LIGHT CAME ON AND STARTED RUNNING ROUGH. I TOOK IT TO MY NORMAL MECHANIC AND HE THOUGHT IT WAS A BAD INTAKE GASKET. HE TORE THE INTAKE OFF, THEN REALIZED THAT CYLINDER 8 WAS NOT GETTING A FIRING PROMPT. I THINK IT IS PROBABLY THE PCM. DOES THAT INVOLVE JUST REPLACING MODULE. DO YOU THINK THAT IS THE PROB? DOES THIS HAPPEN OFTEN IN THE 4.7? I DO NOT WANT TO GO THROUGH THE NIGHTMARE OF HAVING TO MAKE SEVERAL COSTLY TRIPS TO DEALERSHIP. THANKS FOR UR SUGGESTIONS! :thumbsup:
HUSKERJEEP is offline
Body Contorl Module or Door Control Module?? Drdan524 ZJ Grand Cherokee Forum 4 05-19-2010 01:04 PM
RE control arm bushing failure! GrandJC78 ZJ Grand Cherokee Forum 1 11-15-2009 07:59 PM
control arm mount failure - common? what would you do? crozzer ZJ Grand Cherokee Forum 9 08-11-2009 06:13 PM
Bad body Control Module ? jace ZJ Grand Cherokee Forum 6 07-14-2008 06:36 PM
Driver Door Module or Body Control Module ronmaynard ZJ Grand Cherokee Forum 3 04-28-2008 08:13 AM
