4.7 WJ 15lbs of fuel pressure...??? - JeepForum.com
post #1 of 7 Old 08-31-2009, 06:44 PM Thread Starter
cblades83
What would cause this, I have been lurking around and reading all the post on related problems but still no answers. I dropped the tank and installed and new fuel pump assembly yesterday. Still low pressure while running then after i shut off the engine and the pressure drops fast. She has a rough idle but the seems to clear out, but I have to ease the pedal to rev to higher rpms, just cant go to WOT. Any ideas? Thanks!
cblades83 is offline
post #2 of 7 Old 08-31-2009, 06:46 PM
dougy147
Have you changed the fuel filter? I believe the pressure regulator is integrated with the filter in the WJs.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #3 of 7 Old 08-31-2009, 06:52 PM
UrbanOffRoad124
Yep, the pressure regulator is part of the filter. That might be your problem. Change that filter / regulator.
'02 WJ | 4.7HO | Limited | QDII | 3.5" Lift (BB+OME Springs) | JKS TB | JKS Quick Disco's | JKS BPE's | RC Nitro 9000's | Rusty's SS | K&N FIPK | 40 Series Delta | Cat-Delete |
Coming soon: 31" KM2's | 15x8 Cragar V-5's
#236 |
#232
"those who do, can't explain; those who don't, can't understand"
UrbanOffRoad124 is offline
post #4 of 7 Old 08-31-2009, 07:00 PM Thread Starter
cblades83
I give that a shot
post #5 of 7 Old 08-31-2009, 07:47 PM
redwolf698
I agree with these guys, fuel filter is the likely culprit. If that's not it, check for restrictions in the lines, kinks, bends, etc.
Daniel J Fenti
Owner - NC Transmission
2004 WJ Overland lightly modified
Boat Drinks OffRoad Co-Founder
redwolf698 is offline
post #6 of 7 Old 08-31-2009, 08:16 PM Thread Starter
cblades83
thanks guys for the help, try to see what happen's and keep yall updated
post #7 of 7 Old 05-24-2013, 05:20 PM
corymonster
what ever happened here? im in the same boat, but I changed my filter about a year ago, and i just put in a new pump. long crank to start, and rough idle. bad gas mileage. wont accelerate properly
corymonster is offline
No fuel pressure, Fuel Pump? CPS? ECU? Relay? 95cherokee33s ZJ Grand Cherokee Forum 2 10-22-2008 09:57 PM
Fuel Pressure Adriansaxton ZJ Grand Cherokee Forum 2 03-18-2007 03:34 PM
fuel pressure dacecil ZJ Grand Cherokee Forum 7 11-06-2006 02:30 PM
What's my fuel pressure? wmm_16 ZJ Grand Cherokee Forum 4 09-07-2006 12:53 PM
No Fuel pressure JTDEG ZJ Grand Cherokee Forum 7 12-23-2004 06:00 PM
