4.7 tune-up, non H.O. - JeepForum.com
post #1 of 16 Old 01-15-2007, 01:23 PM Thread Starter
H3RESQ
Did a little search. got some spark plug info but that was about it.
What would be recomended in a Tune up for my 01 w/4.7 V8. I change all the fluids regularly but have yet to do a genral tune up. Just wondering what you guys would recomend. BTW It's got about 115K miles.
First I sit and watch. Then I stir the pot!...................................01 4.7 Rockkrawler 6.5 w/37 Krawlers on Allied Monster beadlocks, Auto, Atlas 3.8, 35 spline ARB'd 9 inch rear, ARB'd Piece-o-**** 30 front, etc.
If you have a "It's a jeep thing" sticker then YOU don't understand!!!
H3RESQ is offline
post #2 of 16 Old 01-15-2007, 02:18 PM
Nick ZJ
Nick ZJ's Avatar
I usually do the air filter, spark plugs, distributer cap and rotor, oil, and clean up the battery terminals.
93 zj/4.0/aw4/300/44/70
This is the classic "Unstoppable Force" versus "Immoveable Object" debate. The result? Destruction of the Universe.
last time i tried fording a river 2 of my oxen died and i got dysentary
Nick ZJ is offline
post #3 of 16 Old 01-15-2007, 02:21 PM
AgitatedPancake
sounds good except for the distributor cap and rotor, as we have a seperate coil for each cylinder.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #4 of 16 Old 01-15-2007, 02:30 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yup, there's no plug wires, distributor cap, or rotor.
In addition to what has already been mentioned, you should also clean the throttle body.
Have you replaced any 02 sensors yet? You might consider replacing the upstream sensor at this point if you haven't already.
Wheelin98TJ is offline
post #5 of 16 Old 01-15-2007, 02:37 PM
Nick ZJ
Nick ZJ's Avatar
V-engines are weird.
Nick ZJ is offline
post #6 of 16 Old 01-15-2007, 03:00 PM
Chloetar
It's not that it's a V8, it's the 4.7L hemi they came out with in 1999 that nobody calls a hemi but it really sorta is! Really.
To H3RESQ - I don't know what kind of research you did on the plugs but everyone will tell you to stay away from platinums for this engine. I have platinum plugs in my 4.7, have never had a problem, and don't miss changing #7 and #8 all that much every 30K. The difference in spark conduction must be very minor and over time the platinum gap will not change due to wear.
Alot of guys split hairs on performance, but you won't notice a difference if you have good spark to begin with. I like the fact I don't have to mess with them. Although as an experiment, I did take out the first set of Champion platinums after they had 60K just to see how they looked and they were fine. I put in autolites and have them now. The truck has 107,000 and I plan on keeping it forever.
Finally, if you are going to clean the TB with some good TB cleaner, remove the IAC valve and clean the he!! out of that. You will be amazed at the carbon build up on that.
Good Luck
Chloetar is offline
post #7 of 16 Old 01-15-2007, 03:18 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
Actaully newer TJ's have distributerless 4.0's
2013 FR-S
BlaineWasHere is offline
post #8 of 16 Old 01-15-2007, 03:19 PM
BlaineWasHere
BecauseRacecar
When it gets warm out I better get around to some of this stuff too...
2013 FR-S
post #9 of 16 Old 01-15-2007, 03:41 PM Thread Starter
H3RESQ
So I keep my K&N clean.
So it looks like just the plugs and TB for the most part. Anything else. I'm going to do a TB spacer when I do this. So that will get all cleaned up anyway.
Upstream sensors? I have looked at the exhaust one's when doing that. Not sure what you mean by upstream.
I tend to disconnect the battery during this kind of maintnance. Is there any reason I shouldn't. I figure since I have a chip it's good to let everything reset.
H3RESQ is offline
post #10 of 16 Old 01-15-2007, 04:10 PM
AgitatedPancake
WJ's have 02 sensors before the precats (upstream) and one after (downstream)
Build Thread:
post #11 of 16 Old 01-15-2007, 04:47 PM Thread Starter
H3RESQ
Ok, Thanks. Checked all those when I did the exhaust. They seemed fine. Is there a certain way to check them or just go by how they look?
H3RESQ is offline
post #12 of 16 Old 01-15-2007, 05:06 PM
gunthagunth
gunthagunth's Avatar
You usually just replace them when you throw a code. If theres no code and you still want to replace them it would be just for fun. Although it would help you in the long run. Go to the dealer and grab a can of Mopar Compustion Chamber cleaner. Get the motor up to operating temp. Remove the air tube going to the throttle body, start the motor and spray the entire can in. If the motor sounds like it will stall open the valve up a bit more but try and keep the rpms at idle. Once the can is empty shut off the jeep for 5-10 mins. Once cooled start it back up and let it run for 5 mins at medium idle. It will smoke like a mofo but that will go away. I just did this today due to some recent pinging after startup and slowly accelerating. So far so good no pinging and motor seems quieter. I think there was a sticky valve.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #13 of 16 Old 01-15-2007, 05:13 PM
-Joe-
-Joe-'s Avatar
What "chip" is that?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #14 of 16 Old 01-15-2007, 05:52 PM
jeep_on
Probably one of those $300 Jet-Chips that donít do any thing.
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #15 of 16 Old 01-15-2007, 06:06 PM
BlaineWasHere
BecauseRacecar
I am going to do the upstream 02 sensor in the spring. I am sure it needs to be done. I'll have to email my good friend kolak (20% off mopar parts!)
2013 FR-S
IL 6 Tune-Up cweb ZJ Grand Cherokee Forum 15 02-05-2010 03:06 PM
Bad Tune Up RFisher ZJ Grand Cherokee Forum 16 02-28-2006 04:06 PM
Tune Up? CaptainOats ZJ Grand Cherokee Forum 4 09-25-2005 06:27 PM
tune up Derek33 ZJ Grand Cherokee Forum 15 07-16-2005 10:09 PM
tune-up Derek33 ZJ Grand Cherokee Forum 8 03-24-2005 07:00 AM
