4.7 is porked.... what engines interchange - JeepForum.com
post #1 of 14 Old 05-05-2009, 06:43 PM Thread Starter
chainfeed
Well my problems keep growing.... gf's 01 4.7 grand started running rough and "shaking" as she said.... she parked it and now when I fire it up it clacks like a diesel so its looking like there is some serious stuff wrong with it.
It has been loosing coolant for awhile but the oil has stayed clean and I thought it was going out the heater core (its leaking)...
Can I use a engine from any 99-04 grand? Or will the HO not work? thanks
chainfeed is offline
post #2 of 14 Old 05-06-2009, 10:01 AM Thread Starter
chainfeed
anyone? help
post #3 of 14 Old 05-06-2009, 10:05 AM
alexsious
replace it with another 4.7 from any 99-04
alexsious is offline
post #4 of 14 Old 05-06-2009, 10:07 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
For the most part, you need to stick with '99-'01 because the tone wheel on the crankshaft is 16 teeth. '02-'04 generally has 32 teeth, however, you can find a newer one with only 16 teeth. Use car-part.com and search for different years, but make sure you look for 16 toothed tone wheel.
You may be able to add an HO, but since you can't use the HO computer you are stuck with running nothing but 93 octane.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 14 Old 05-06-2009, 10:07 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
SERIOUSLY?!?!?!
or are you DEAD WRONG?
post #6 of 14 Old 05-06-2009, 10:34 AM
aaron7
http://www.monicattichrysler.com/com...idProduct=1395
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
post #7 of 14 Old 05-06-2009, 10:57 AM
alexsious
Originally Posted by QuadraTokn View Post
SERIOUSLY?!?!?!
after last night, the latter. what was wrong with my statement?
post #8 of 14 Old 05-06-2009, 12:07 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
umm he can't just use any 99-04 engine, it has to have the correct tone wheel for a direct swap.
post #9 of 14 Old 05-07-2009, 07:46 AM
dorman68
Here is info I got from a salvage parts interchange index
GRAND CHEROKEE 1999-2000 8-287 (4.7L, VIN "N", 16 tooth crankshaft tone wheel)
These truck engines will fit with the following changes -
DAKOTA 2000 4.7L (8-287, VIN "N", 16 tooth crankshaft tone wheel)
DURANGO 2000 4.7L (8-287, VIN "N", 16 tooth crankshaft tone wheel)
Chrysler 8-287 (4.7L).
VIN "N".
235 H.P.
S.F.I.
Change electrical and induction / intakes systems as needed.
- interchange by switching oil pan.
dorman68 is offline
post #10 of 14 Old 05-08-2009, 02:50 PM Thread Starter
chainfeed
gave in and took it to a garage....
Mechanic found a bad lifter which let the cam follower to fall out, so he says. Replaced them and now it runs good again.... Only 645 bucks.... barf
Between this, the leaking heater core and a bad ps pump all at 100k miles I'm thinking we're gonna dump the WJ, its really been a huge pain in the *** in the year that we have had it.
post #11 of 14 Old 05-08-2009, 11:05 PM Thread Starter
chainfeed
well when we went to pick the crap box up it is still ticking away pretty loud...... this jeep sucks
post #12 of 14 Old 05-09-2009, 12:24 AM
steelstr45
your mechanic better fix it again for free.
steelstr45 is offline
post #13 of 14 Old 06-02-2009, 03:42 PM
ridewright
Did you get all new lifters (lash adjusters), or just one for each fallen rocker?
ridewright is offline
post #14 of 14 Old 06-02-2009, 05:27 PM
subliminal
1997 XJ Cherokee
I hear the 4.7 will bolt right in.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
4.0 ECM Interchange?????? SD-Pimpin ZJ Grand Cherokee Forum 2 01-06-2010 12:30 PM
44RE interchange? Area.3.Fiftyone ZJ Grand Cherokee Forum 2 10-12-2009 03:20 PM
ZJ: Need front driveshaft... what models/engines/etc interchange? aaron7 ZJ Grand Cherokee Forum 7 05-10-2009 05:26 PM
ZJ door interchange white95zj ZJ Grand Cherokee Forum 2 09-14-2008 10:17 PM
Zj tranny interchange from 96 to 97 stonepony1975 ZJ Grand Cherokee Forum 5 09-13-2006 11:18 AM
