4.7 misfire after head replacement - JeepForum.com
post #1 of 3 Old 05-31-2009, 04:40 PM Thread Starter
dougy147
So I finally got a good set of heads and put everything back together. But now that it's running again i'm having a little issue. It idles very rough and seems to get worse as the temp goes up. I've unplugged a few coils while it's running and it dosn't seem to make a difference in how it idles. Once you get going everything seems fine, acceleration is good and it runs pretty smooth at speed.
Just for a little background I had a cracked head. I replaced both with reman heads. I'm 99.99% sure the timing is correct. I had all the plated links lined up per the FSM and when I installed the crank pully and lined up the marks on the pully and timeing cover the cams were exactly where they should be. I also replaced the water pump and some other misc. stuff while I had it apart but I don't think any of that would make a difference. I did have to replace the cam sensor, I must have stuck it in a magnetic tray at some point and destroyed it and the one I put in was not mopar.
The following codes came up:
0132 - Bank 1 Sensor 1 02
1492 - battery temp sensor voltage out of range
0305 - Cyl 5 misfire
0353
0355
0357 - These are all max coil resistance not reached but are likely from me unplugging the coils.
None of these were present before doing the heads.
The oxygen sensor code was cleared and has returned. I had it hooked up to a scanner and graphed the right and left bank upstream oxygen sensors and they seemed to track each other very well so it dosn't seem like the pcm is getting a crazy reading from that sensor, so i'm not quite sure what to make of it.
Opinions? Suggestions? PLEASE! I've been driving a 97 civic for 3 weeks while I waited for a second set of heads after the first was damaged.....I miss my Jeep!
I'm not sure where to turn with this except the oxygen sensor or the non-mopar cam sensor. I don't think either of these would cause a rough idle/misfire condition though.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #2 of 3 Old 05-31-2009, 09:27 PM
baxy
investigate the #5 cylinder missfire
low compression,bad spark plug,bad injector, bad wiring,bad coil ,bad valves
baxy is offline
post #3 of 3 Old 06-02-2009, 11:39 PM Thread Starter
dougy147
FIXED!
I had thought the misfire code was because I had been messing with the coils. When I went to clear the codes to start fresh again there was freeze frame data available for the misfire code. Come to find out, I was going 15 mph when the code occurred, so it was clearly not when it was parked in my driveway while I was messing with it. Pulled out #5 plug to find a gap of exactly 0.00. I must have messed it up when I put it in, to go through all that and screw up a spark plug! Anyway, runs great now.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
4.0 head gasket replacement ras2001wj ZJ Grand Cherokee Forum 12 09-29-2009 10:41 AM
Look of Panic after Head gasket replacement madmarchhare ZJ Grand Cherokee Forum 4 08-05-2008 08:46 AM
head lamp bulb replacement JeremyBelnap ZJ Grand Cherokee Forum 7 06-23-2006 05:47 PM
Head unit replacement BradTE20 ZJ Grand Cherokee Forum 6 12-13-2005 02:17 PM
Head Gasket Replacement on 5.2 L Done! Jim Moore ZJ Grand Cherokee Forum 3 08-23-2004 11:22 PM
