4.7 HO piston slap - JeepForum.com
post #1 of 6 Old 08-15-2009, 10:12 PM Thread Starter
JForest2
4.7 HO piston slap
Just got a question for all you experts out there.. I picked this jeep up a couple of months ago and never really noticed that when engine is cold and I start it up, after about 10-15 I get this clacking noise in the engine and it last for maybe about 30-40 secs and then stops.. It doesn't do it when the engine is warm only when its been sitting overnight.. I've changed the oil and put a good filter on there.. Could this be piston slap? It's not a heavy thud sound like if it was a rod bearing, it's more a lighter clack sound and is very speratic.. It does it at every start up but it's not a constant noise, it comes and goes in that 30-40 secs..
It's a 4.7 HO with 60k
James
JForest2 is offline
post #2 of 6 Old 08-16-2009, 06:28 AM
cmonson
is it knocking? What fuel are you using?
cmonson is offline
post #3 of 6 Old 08-16-2009, 09:43 AM
rm2001wj
rm2001wj's Avatar
My 01 standard 4.7 has done that for years. I strongly believe that it is piston slap. It's annoying, but not much to worry about.
rm2001wj is offline
post #4 of 6 Old 08-17-2009, 10:28 AM
jack9580
2014 WK
how about a leaking exhaust manifold gasket? as soon as it warms up the metal expands and seals up the leak. I had this fixed on mine when i frist bought it.
2014 WKII Summit (Let the madness begin)
2004 WJ Freedom Edition w/4.7 H.O. heavily modded. Best car ever!!!!!!(sunk + totaled R.I.P. 9/06)
1998 TJ Sahara lifted, locked, and tons of crap bolted on (Sold)
2004 WJ limited w/4.7 H.O. Addco rear bar, JK Rubi wheels. (t-boned and totaled)
jack9580 is offline
post #5 of 6 Old 08-17-2009, 10:54 AM
trailblaze
trailblaze's Avatar
^ my exhaust leaks too. goes away when warm.
4.7 HO too. wonder if this is a common problem
Matt
trailblaze is offline
post #6 of 6 Old 08-17-2009, 11:29 AM
iluvtruenos
If it does this only when cold and overnight, have you thought that you might be losing oil pressure?
Is your gauge a dummy gauge or a real gauge? Does it start off at 3/4 when cold, then settle down a little bit past 1/2 when warm? Or does it stay at the same location the entire time, regardless of engine warmth?
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
overheating slap RockScar WJ Grand Cherokee Forum 11 01-08-2013 08:32 AM
Piston Ring Help jeepdudeuk ZJ Grand Cherokee Forum 1 10-01-2009 09:37 PM
Engine Rattle Piston Slap!!!! jeepdudeuk ZJ Grand Cherokee Forum 2 09-18-2009 07:27 AM
Piston size? 95 v. 97 Vestjam ZJ Grand Cherokee Forum 0 12-18-2006 04:46 PM
new caliper piston captain_andrew ZJ Grand Cherokee Forum 1 05-31-2004 01:54 AM
