4.7 engine swap won't run code P1389 ASD - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 4.7 engine swap won't run code P1389 ASD
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 11-25-2008, 09:37 AM   #1
meat27
Just dropped a replacement 4.7L into an '01 GC Ltd.
The motor spins over but won't run.
It stores code P1389. I have found the definition for the code, but I don't have any experience with an "Auto Shutdown..........."
Any ideas on where to start?????
meat27 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2008, 09:44 AM   #2
-Joe-
P1389 (M)
No ASD Relay Output Voltage At PCM
No Z1 or Z2 voltage sensed when the auto shutdown relay is energized.
P1389 (M)
An open condition detected In the ASD relay output circuit.
Loose connection or bad relay?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote Quick reply to this message
Unread 11-25-2008, 09:50 AM   #3
meat27
Just found the problem.
I had seen other people swapping the relays, so I did that, still had problem, and jumped on here.
Then took another look and found and ASD 30A fuse blown. Swapped it and runs good. Duh. Sorry I jumped on here without going through the fuses first.
Thanks for the advice Joe
