4.7 engine swap won't run code P1389 ASD - JeepForum.com
post #1 of 3 Old 11-25-2008, 08:37 AM Thread Starter
meat27
Just dropped a replacement 4.7L into an '01 GC Ltd.
The motor spins over but won't run.
It stores code P1389. I have found the definition for the code, but I don't have any experience with an "Auto Shutdown..........."
Any ideas on where to start?????
meat27 is offline
post #2 of 3 Old 11-25-2008, 08:44 AM
-Joe-
-Joe-'s Avatar
P1389 (M)
No ASD Relay Output Voltage At PCM
No Z1 or Z2 voltage sensed when the auto shutdown relay is energized.
P1389 (M)
An open condition detected In the ASD relay output circuit.
Loose connection or bad relay?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 3 Old 11-25-2008, 08:50 AM Thread Starter
meat27
Just found the problem.
I had seen other people swapping the relays, so I did that, still had problem, and jumped on here.
Then took another look and found and ASD 30A fuse blown. Swapped it and runs good. Duh. Sorry I jumped on here without going through the fuses first.
Thanks for the advice Joe
meat27 is offline
Engine code Uncle_Fester ZJ Grand Cherokee Forum 1 10-11-2009 06:19 PM
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-06-2009 11:56 PM
Engine Code 31 Jagillac ZJ Grand Cherokee Forum 1 12-29-2008 01:35 PM
Engine code 32 lma1973 ZJ Grand Cherokee Forum 9 02-05-2008 12:49 PM
Engine Code P0.601 SVTCobraLTD ZJ Grand Cherokee Forum 3 11-18-2007 02:34 AM
