4.7 dies......flooding? - JeepForum.com
post #1 of 8 Old 07-03-2009, 10:04 PM Thread Starter
CHm0074
our 03 grand with the 4.7 died on my wife..while she was on the interstate. no warning and no previous problems. when i had it towed to garage....it flooded while they were checking it and filled the cylinders and gas came back out of the intake, filling the the intake box where the filter is....garage says they have never seen this before.....any ideas?.....thanx.....
91 yj 4.0 auto 4 inch rough country 33 12.50s...mostly stock
CHm0074 is offline
post #2 of 8 Old 07-04-2009, 07:46 AM Thread Starter
CHm0074
any ideas please??
CHm0074 is offline
post #3 of 8 Old 07-04-2009, 07:57 AM
madmechanic
the fuel pressure regulator could have failed causing the fuel pressure to spike to extremely high pressure. i had it happen on a ford truck one day while we had a gauge hooked up to it press. went up to 100-110 psi and fuel flooded the cylinders. but only thing is that was a ford truck and you have jeep. what is the cranking fuel pressure?
madmechanic is offline
post #4 of 8 Old 07-04-2009, 09:38 AM Thread Starter
CHm0074
thank you for the reply but i dont know the cranking fuel pressure and the mechanic didnt say....ill try to check but dont have a gauge
CHm0074 is offline
post #5 of 8 Old 07-20-2009, 09:46 PM Thread Starter
CHm0074
finally got pressure gauge on it......read 60 at initial crank and then drops to about 48.....needle on guage jumping whole time...regulator or pump?
CHm0074 is offline
post #6 of 8 Old 07-20-2009, 10:19 PM
WiCkeDuDe
WiCkeDuDe's Avatar
A wj with the 4.7 does not have a regulator. Pump pressure should be 49.2 +/- 5 psi at idle. Can you get it fired and take a pressure reading? Sound likes you have one or more flooding fuel injectors. I have not seen a pump cause this before but I have not worked on many 4.7s.
WiCkeDuDe is online now
post #7 of 8 Old 07-21-2009, 07:07 AM
rm2001wj
rm2001wj's Avatar
The only way fuel can get into the intake manifold and cylinders is through the injectors. There is definitely something wrong with one or more fuel injectors and they are either stuck in the open position or cracked so that they leak. I'm surprised people at the garage couldn't figure this out.
BTW, the fuel pressure regulator is combined with the filter into a single unit performing two functions.
rm2001wj is offline
post #8 of 8 Old 07-21-2009, 07:34 AM
Double E
Double E's Avatar
Isn't this the infamous "died on the highway" symptom that points to the CPS? I haven't had it happen to me yet but I thought this situation sounded pretty familiar to the CPS being bad.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
1993 grand waggon 5.2L V8 flooding out ECMUDSLINGER ZJ Grand Cherokee Forum 4 12-01-2009 10:35 PM
4.7 flooding and then stalling out GeorgeTown ZJ Grand Cherokee Forum 4 05-02-2009 10:04 PM
Rough Idle / Dies when changing gears / Dies in low RPM's only MFS_WJ ZJ Grand Cherokee Forum 3 09-02-2007 02:18 PM
ZJ Flooding on the passenger side floor. Need advice JimJimBinks ZJ Grand Cherokee Forum 15 06-24-2007 12:10 AM
'05 WK Flooding? alinn ZJ Grand Cherokee Forum 5 06-16-2005 02:59 PM
