4.6 Stroker Builder Do Not Buy from! - JeepForum.com
post #1 of 13 Old 10-31-2016, 01:10 AM Thread Starter
cnw12079
So I thought since my original 96 ZJ motor was close 300k miles it would be a good time to replace. So I found an add on eBay and it just so happens that the guy is just a few miles down the road from me. Had build one installed and got to about 2500 miles and had this horrendous clacking coming from the motor. Come to find out the cam was walking so bad that the rotor button was hitting the top of distributor cap. Uneven wear on the cam journals. Also let's not forget the aluminum shavings in the oil. Also it appears that is bore was done incorrectly and was to tight causing the pistons prematurely wear to friction and heat... I have added pics of his website and eBay auction. He is already back peddling on trying to warranty the motor so buyer beware and learn from my mistake!
http://www.outletengines.com
cnw12079 is offline
post #2 of 13 Old 10-31-2016, 10:46 AM
jb1331
I was just in that area last week (work related travel).. Seems like a really low price as many other shops want $3k(+) for a stroker build. I guess you get what you pay for.. good luck with getting that warrantied / replaced.
1997 ZJ Laredo 4x2 I6 Bought in 1999 @29k, 174k
2004 Jeep Liberty LTD. Bought 7/31/16 @ 119k
jb1331 is offline
post #3 of 13 Old 10-31-2016, 11:17 AM Thread Starter
cnw12079
Yeah I took stab at it since it was local and at the time I couldn't find anything negative about his builds. Either he has just gotten lucky on what he has sent out before mine but it was a crap build
cnw12079 is offline
post #4 of 13 Old 10-31-2016, 12:30 PM
stevo_96ZJ
thanks for the info CNW. I live in greensboro so not far from cary and also have a 96 ZJ and I really want to swap in a stroker on mine but I only have a little over 100k miles on mine so I plan to wait till I pile on some more. If you decide to build your own and need some help let me know since I am pretty close.
Whats a ZJ? If you have to ask you can't afford it.
stevo_96ZJ is offline
post #5 of 13 Old 10-31-2016, 12:35 PM
Uniblurb
Uniblurb's Avatar
They aren't BBB accredited and only 1 review which isn't good.
http://www.bbb.org/raleigh-durham/bu...stomer-reviews
And the majority of google reviews are bad.
https://www.google.com/search?q=comp...de6fbfcf869,1,
If you don't receive any action or they don't honor the warranty you can always file a complaint with the NC Dept. of Justice, Attorney General.
http://www.ncdoj.com/Consumer/2-2-12...Complaint.aspx
Needless to say most businesses in the state they reside do not want to face complaints by the state DOJ/Attorney General. It may be worth mentioning filing this complaint only if you don't receive any immediate action.
Welcome to the forum, wish it was under better circumstances, and good luck!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #6 of 13 Old 11-01-2016, 09:38 AM
zjosh93
Sucks that your new motor is wounded.
Cam walk won't make the rotor hit the cap. The extent to which the distributor shaft can move is limited by the shaft collar on the distributor. Nothing to do with the cam. You say the cam journals are worn unevenly? Cam bearings usually barely wear at all. What kind of wear are you seeing? How much aluminum and what size shavings? What indications do you have that the bore is wrong? Any pics?
zjosh93 is offline
post #7 of 13 Old 11-01-2016, 11:51 AM
waxx25
A stroker for $1400.....I would not expect much at all for that price.
waxx25 is offline
post #8 of 13 Old 11-01-2016, 11:57 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
that header is purdy^
definitely the highlight of this thread
HighLonesome is offline
post #9 of 13 Old 11-01-2016, 12:07 PM
BorderWalker
For sure. I took one look at the Header and had to excuse myself to my bunk.
._________.ooooo.
/ŻŻŻ|ŻŻ|ŻŻ\ŻŻŻŻŻ\,____
L/ŻŻ\\__|__|"/ŻŻŻ\=llllll=\
_(Ż))===)).....(Ż))===))Ż
BorderWalker is online now
post #10 of 13 Old 11-01-2016, 09:24 PM Thread Starter
cnw12079
ForumRunner_20161101_232248.jpg   ForumRunner_20161101_232257.jpg   ForumRunner_20161101_232304.jpg   ForumRunner_20161101_232316.jpg   ForumRunner_20161101_232328.jpg
cnw12079 is offline
post #11 of 13 Old 11-01-2016, 09:25 PM Thread Starter
cnw12079
He started throwing out excuses from the get go but I have everything documented for civil case to recoup my money.
cnw12079 is offline
post #12 of 13 Old 11-01-2016, 09:29 PM Thread Starter
cnw12079
Stevo it wont let me respond back to you in PM but when I get back to rebuilding the stroker I will let you know.
cnw12079 is offline
post #13 of 13 Old 11-02-2016, 11:48 AM
zjosh93
Looks like normal break in wear for a flat tappet cam but it's hard to tell for certain from the pics. The scuffed pistons are bad news. It's hard to get a machine shop to cover that kind of thing. Good luck. They usually have some fine details in the warranty to trip up claims. For example, your guy says you must run Lucas oil stabilizer in the first oil change and change oil after 500 miles. He's betting you don't have the receipts and he can summarily dismiss your claim.
zjosh93 is offline
