4.0L timing chain - JeepForum.com
post #1 of 8 Old 02-01-2007, 09:21 AM Thread Starter
jeepunlimited
4.0L timing chain
hey guys, i have a knocking sound coming from the front of my 4.0L down low, and im just wodnering what the life span for the timing chain on a 4.0L is.....i want my jeep to last me a bit longer but i was thinkin now that knocking sound could be a bad timing chain ?? it starts right up but seems down on power sometimes, i dunno.....anyone know how long a timing chain usually lasts on a 4.0L has anybody changed one and if soo what is hard ??
hopefully i can do it with the engine in the jeep
thanx guys....
any help would be great
jeepunlimited is offline
post #2 of 8 Old 02-01-2007, 01:30 PM
yrubugn
Well I never had to change one as most dont stretch or break too often.
But to check the chain you can remove the distributer cap and rotate the motor by hand using the belt or pulleys. Turn counterclockwise to take the slack out of the chain, then slowly turn clockwise, noticing how far before the rotor moves.
If the pulleys go an inch or so the chain is stretched and should be changed, it is usually noticeable by more of a slapping noise.
yrubugn is offline
post #3 of 8 Old 02-01-2007, 01:39 PM
cmonson
I don't think the 4.0 is a 0 (zero) clearance engine.
That being said, if the chain breaks, the valves will not hit the pistons. Verify this though.
Being a non-zero clearance engine, if the chain snaps, it will not do any damage. You will just have to install a new chain.
cmonson is offline
post #4 of 8 Old 02-01-2007, 08:48 PM
kentman
kentman's Avatar
2006 XK Commander
I'm at 213K on the original chain, and I am just going to let it ride for now. I had a friend at work claim that he threw one at 241K, and that was the end of the road for him. I do not believe that throwing a chain always ends happily with the installation of a new chain.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #5 of 8 Old 02-01-2007, 08:53 PM Thread Starter
jeepunlimited
what do you mean ??? if the 4.0L is a non interference motor, why wouldnt a new chain fix it ?? maybe i should do mine in the warm wheather
post #6 of 8 Old 02-02-2007, 09:46 AM
cmonson
Non-interferance engine = when the chain breaks, the intake and exhasut valves will not come in contact with the pistons.
On an interferance engine, when the chain or belt break, the valves come in contact with the pisons. This causes engine damage that would result in a rebuild.
cmonson is offline
post #7 of 8 Old 02-02-2007, 09:52 AM
nitecop
Chains don't typicly break at all. If it does break while the pistons might hit the valves, you will most likely need a new aluminum timing cover.
AND a ride home for you and your vehicle.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #8 of 8 Old 02-02-2007, 11:15 AM
GreenDean
GreenDean's Avatar
This is true.
I had a Ford 5.0 that had countless miles on it.
It needed a chain.
Old one was loose enough to tie a knot it.
I replaced the chain and the motor never ran right again.
GreenDean is offline
64 chain timing set up jeep795 ZJ Grand Cherokee Forum 0 05-16-2009 10:29 AM
Timing Chain?? 1994LTD ZJ Grand Cherokee Forum 5 06-11-2008 06:23 PM
4.0L timing chain ? jeepunlimited ZJ Grand Cherokee Forum 10 07-29-2007 08:11 PM
Timing Chain eagleknight ZJ Grand Cherokee Forum 5 06-17-2006 11:22 PM
Timing Chain Tenssion Jgw50 ZJ Grand Cherokee Forum 1 09-01-2005 08:32 PM
