4.0L Rough idle/misfire(?) when engine is warm... - JeepForum.com
post #1 of 11 Old 09-05-2009, 08:37 AM Thread Starter
skinnyjl
I have a 2004 Grand Cherokee with a 4.0L engine and 99k on the clock. The check engine light has come on and I get an intermittent rough idle (500-600rpm) and misfiring/poor performance at highway speeds and when I put a load on the engine (going up a steep grade, ect..) This seems to happen when the engine is at operating temp (~180-200F). Sometimes the engine light will flash when the engine is running poorly. I have put new plugs and a new coil pack in and my mechanic tracked down 3 vacuum leaks, but the problem still persists. The kicker is, engine runs fine before it gets to operating temp. I really don't want to go the dealership route, as the $100 per hour labor rate is hard on my limited income.
skinnyjl is offline
post #2 of 11 Old 09-05-2009, 09:14 AM
SouthSeaPirate
Flashing engine light is usually a missfire indicator. And if Im not mistaken, the amount of flashes will inticate what cyl it was.
When your running cold your ride is in sort of a limp mode. It wont use such things like O2 sensors and a few other sensors until its warmed up. Could be something along those lines.
An 'early' educated guess would be TPS, CPS or PCM. I would also check the vacuum line to the MAP sensor. But to early to tell anything just yet. So get the codes pulled asap.
Also check the oil for water and water for oil. Any smoke coming out of the tail pipe? I would check these first. Then MAP vacuum and then get the codes pulled.
SouthSeaPirate is offline
post #3 of 11 Old 09-05-2009, 09:18 AM Thread Starter
skinnyjl
No smoke or water and oil in the wrong places. Just the occasional whiff of unburnt gas.
skinnyjl is offline
post #4 of 11 Old 09-05-2009, 09:21 AM
SouthSeaPirate
Good thing, get those codes pulled and back to us.
post #5 of 11 Old 09-05-2009, 11:07 AM Thread Starter
skinnyjl
I was able to pull the codes using the "key method" and got the following:
P0202 - Injector Circuit Malfunction - Cylinder 2
P0302 - Cylinder 2 Misfire Detected
P0442 - Evaporative Emission Control System Leak Detected (small leak)
skinnyjl is offline
post #6 of 11 Old 09-05-2009, 11:41 AM
4Slow9erHybrid
Disconnect the upstream O2 sensor. If the problem goes away, you diagnosed a failing O2 sensor. But remember this is just a test, don't drive like this for prolonged time. Replace with genuine Mopar O2 sensor ONLY!!! This is quite a common issue with the 4.0 Grands.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #7 of 11 Old 09-05-2009, 05:25 PM Thread Starter
skinnyjl
I pulled the plug on the O2 sensor and it didn't seem to change much.
skinnyjl is offline
post #8 of 11 Old 09-06-2009, 06:56 AM
20jeepwj00
If you have an injector circuit code it could be an injector,when the injector gets hot it could be failing,when the problem is occuring pull off the #2 injector connector and install a noid light an if its flashing the wiring and the controller are ok and its probably a bad injector.
20jeepwj00 is offline
post #9 of 11 Old 09-06-2009, 08:02 PM Thread Starter
skinnyjl
B..u..m..p
skinnyjl is offline
post #10 of 11 Old 09-08-2009, 04:51 PM
JonM81
Oh my... I may have a bad injector... Got the same thing with all the O2 sensors replaced... I was hoping it was the spark plugs... eeek
Jon
La Vernia, TX
2004 WJ Grand Cherokee Laredo
4.0L Straight Six w/ 140xxx Miles
K&N Drop In w/ Air Box Mod
JonM81 is offline
post #11 of 11 Old 09-19-2009, 01:01 PM Thread Starter
skinnyjl
Just a follow up...
After my mechanic decided I had a bad computer, I wasn't convinced. So, I gave in and took it to the $tealer$hip. They determined I had a short in the engine harness that was causing the misfire. I picked it up yesterday and all seems well so far. No CEL or codes and it seems to be running well. I just hate the fact that it cost me $506 for a tech to put shrink insulation around a bare wire. Oh well... I knew I was going to get screwed when the service rep said that it was a 5 hour job before they even did the work. It could have taken them 5 hours or it could have taken them 45 minutes. I'll never know...
skinnyjl is offline
Rough Idle / WARM engine WJ 4.0 KaiTTown ZJ Grand Cherokee Forum 15 02-27-2013 03:36 PM
Rough Idle after start up... Cranks for a long time when warm... Krayzie949 ZJ Grand Cherokee Forum 0 02-08-2010 06:09 PM
rough idle untill warm QM2Rick ZJ Grand Cherokee Forum 1 03-06-2007 06:08 AM
97 Grand Cherokee V8 rough idle/stalling when warm Ward83 ZJ Grand Cherokee Forum 3 01-28-2007 05:35 PM
