4.0L head bolt loosening sequence? FSM doesn't say. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 4.0L head bolt loosening sequence? FSM doesn't say.
Unread 05-06-2013, 10:18 AM   #1
AVR2
I'm poised to loosen the head bolts on my 4.0L, but the FSM doesn't specify a sequence for loosening, only for tightening. I guess that means the reverse of the tightening sequence would make sense?
AVR2 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 10:29 AM   #2
ratmonkey
R.I.P.
ratmonkey's Avatar
No sequence for it. Just take them out as you get to them.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 11:10 AM   #3
AVR2
OK, cool. So it really doesn't matter for loosening? A few minutes ago I found a post in the XJ forum here where someone was absolutely definite that you *had* to use the reverse of the tightening sequence or else you'd run a serious risk of warping or cracking the head.
