4.0L Coolant level - JeepForum.com
post #1 of 3 Old 12-22-2008, 02:33 PM Thread Starter
tfgnt16
2009 WK
4.0L Coolant level
I've got an '01 WJ and noticed that the coolant level in the reservoir is slowly, but surley decreasing in level despite the engine being hot or cold (I already checked that to make sure.) I'm also blowing a small amount of white smoke out of the exhaust, and yes it has that sweet smell. Anyone have any idea what the problem may be?
I know what most of you are going to say and I'm praying it isn't the head gasket. Luckly the truck is under warranty with the dealer.
Thanks
2001 WJ Laredo 4.0L - Sold!
2009 WK Limited 5.7L HEMI
tfgnt16 is offline
post #2 of 3 Old 12-22-2008, 06:05 PM Thread Starter
tfgnt16
2009 WK
Any help would be greatly appreciated, thanks.
tfgnt16 is offline
post #3 of 3 Old 12-22-2008, 07:15 PM
ZeeJay1997
CYLINDER-TO-WATER JACKET LEAKAGE
TEST
WARNING: USE EXTREME CAUTION WHEN THE
ENGINE IS OPERATING. DO NOT STAND IN A
DIRECT LINE WITH THE FAN. DO NOT PUT YOUR
HANDS NEAR THE PULLEYS, BELTS OR THE FAN.
DO NOT WEAR LOOSE CLOTHING.
Remove the radiator cap.
Start the engine and allow it to warm up until the
engine thermostat opens.
If a large combustion/compression pressure leak
exists, bubbles will be visible in the coolant.
If bubbles are not visible, install a radiator pressure
tester and pressurize the coolant system.
If a cylinder is leaking combustion pressure into
the water jacket, the tester pointer will pulsate with
every combustion stroke of the cylinder.
ZeeJay1997 is offline
2001 GC low coolant level light Steve in PA ZJ Grand Cherokee Forum 2 10-18-2008 11:30 AM
Low coolant level kopite77 ZJ Grand Cherokee Forum 14 02-12-2007 09:53 AM
Coolant Level Low??? Jay Arno ZJ Grand Cherokee Forum 4 01-26-2005 07:08 PM
Coolant level sensor bad - is this serious? Gracie ZJ Grand Cherokee Forum 10 11-18-2004 07:19 PM
low coolant level alarm msafrit ZJ Grand Cherokee Forum 3 01-23-2003 07:52 PM
