4.0 ZJ turns over but won't start - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 4.0 ZJ turns over but won't start
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 09-01-2013, 07:46 PM   #61
Oldfrog
You arent done yet, grasshopper. Zeejay will now probably walk you thru the crank sensor testing procedure. Thank HIM. He's awesome !
Cajun Recipes and Fishing tips
On 7th PCM. Finally got a good one.
Stalling? Work through Zeejay's list
God Bless the Garland, TX Police Dept.
Oldfrog is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 07:48 PM   #62
JBrady5555
So why would crank sensor make the fuel pump not work?
JBrady5555 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 07:57 PM   #63
Oldfrog
Switch "ON": ( engine not running):
Open loop mode. PCM prepositions IAC motor based upon engine coolant temp. Gets info from MAP sensor, intake air temp, and TPS input. It activates auto shutdown relay, which activates fuel pump relay for 3 seconds unless engine is cranked. If engine doesnt crank, fuel pump relay ( via autoshutdown relay) is shut off.
At start up:
The computer gets info from the crank sensor, TPS, battery voltage, cam sensor, engine coolant sensor, IAT and Map. Based on those inputs, voltage is applied to the injectors.
Unread 09-01-2013, 08:04 PM   #64
Oldfrog
The TPS, Map sensor and crank sensor share the same 5 volt supply feed. If one of those pulls that 5 volts down to ground, then it affects all three.
Unread 09-01-2013, 08:15 PM   #65
JBrady5555
Awesome thanks
Unread 09-01-2013, 08:30 PM   #66
ZeeJay1997
Go ahead and order a Mopar crank sensor.
IMO, no other testing is necessary.
If you just want to hone your meter using skills, here's the test.
If it reads between 0 and 10k ohms, its bad.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 08:35 PM   #67
JBrady5555
Ok gonna order the molar sensor, any tricks I need to know for removal and installation?
Unread 09-01-2013, 08:38 PM   #68
ZeeJay1997
it's strange that you zapped your crank sensor by shorting the battery posts. I was expecting the PCM to be zapped. You may not be out of the woods yet, but you're not even going to be on the trail with a shorted crank sensor.
Unread 09-01-2013, 08:43 PM   #69
ZeeJay1997
you'll need a lot of patience, I changed mine out several years ago and all I remeber about was that I made up some cuss words, used a long 1/4 extension, a taped up swivel, and a 10mm socket from underneath the vehicle. It helps to have someone up top to help keep the the tools on the bolt.
The sensor will come with a felt tip on the end. leave it on there and push the sensor in as tight as you can with one finger, then tighten the bolt.
Unread 09-01-2013, 08:50 PM   #70
Oldfrog
I hope you have small hands....because it's a biotch unless you want to remove that dang ....TV ? ..cable. I think I used a LONG extension AND another 10 inch extension with a taped up wobble joint. Came up from the back of the tranny, as I recall.
Unless you want to perform this task again, get ONLY a Mopar CPS. Dont try to save $ by using an aftermarket sensor.
Unread 09-01-2013, 09:04 PM   #71
ZeeJay1997
And also, be sure the switch is off and disconnect the battery now While you have it disconnected, clean the two grounds on the side of the block that Oldfrog was telling you about earlier. They are critical to your fuel/ignition system.
Unread 09-02-2013, 01:40 PM   #72
JBrady5555
Does it have to be mopar? Advanced only has bwd in stock.
Unread 09-02-2013, 01:58 PM   #73
Oldfrog
Yes. It HAS to be Mopar....or you'll be removing it and doing it again a day later.
Unread 09-02-2013, 03:12 PM   #74
ZeeJay1997
call the dealership and price one. this is the part number you need
There are other mopar retailers online but I cant attest to their service.
I've been running a Sorenson from NAPA for a few years with no problems, but i could have had a Mopar for the same price.
Unread 09-02-2013, 03:33 PM   #75
JBrady5555
Mopar it is, thanks guys
